What should I use in my model A tranny?
Discussion in 'The Hokey Ass Message Board' started by Mopar4Life64, Mar 7, 2014.
  1. Mopar4Life64
    Mopar4Life64
    from Shreve
    I have a bone stock 1929 model a and was wondering what fluids I should use in the transmission and where where at on the transmission do I drain the old and put in the new?
  2. Mopar4Life64
    Mopar4Life64
    from Shreve
    The transmission wines really loud in 1st and 2nd gear. Enough to where you can't hear your p***ager next to me talking. Is that normal on these cars? I'm afraid I'm going to burn up the ****** if I drive it.
  3. Fenders
    Fenders
    Does not sound normal, I've had a couple that were fairly quiet in 1st and 2nd.
    fordbarn.com good place for stock A questions -- don't mention any mods to that car ha ha
  4. Grnegg
    Grnegg
    I run a mix of STP® and gear oil (80wt) in mine. It may sound too thick, but it helps to slow down the unsynchronized gears for easier shifting.
  5. spooler41
    spooler41
    Most early Ford transmissions and rear ends call for 90 wt. gear oil.
    .......................... Jack
  6. Mopar4Life64
    Mopar4Life64
    from Shreve
    Lol ok thanks. I didn't think it was normal but wasn't sure. This is my first model A
  7. Mopar4Life64
    Mopar4Life64
    from Shreve
    Ok thanks. How do you change it?
  8. Mopar4Life64
    Mopar4Life64
    from Shreve
    Also how much does it take
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    Plug on bottom -fill to over flowing plug on side of trans. That trans has straight cut gears and they will make some noise. A Model A is about as smiple a car as there is. May I suggest getting a few books on the subject and doing some reading.
  10. Mopar4Life64
    Mopar4Life64
    from Shreve
    Ok thanks john.
  11. We have a stock 3 speed in our 36 Ford. I use regular 90 wt gear oil and added a can of STP and seems to work well.
    This is not an A ****** but I'm thinking you still shouldn't have excessive whine?
  12. Chris
    Chris
    They use 600wt in it. No joke. It is like tar. You can get it from patrolium places or any restoration place has it. 90wt is too light.
  13. JohnEvans
    JohnEvans
    from Phoenix AZ
    That 600W is more like regular 140W which is what I would use.
  14. Chris
    Chris
    140 is quite a bit lighter then 600...it may work. I used 600 in the trans, read and steering boxes of my A's and it worked well
  15. plym49
    plym49
    from Earth
    600w is not 6 times as thick as 90w. They are measured on different scales.
    You can Google an equivalency scale that shows the relative viscosities of, say, 40w motor oil, 90w gear oil and that '600w'. Not as far apart as you would think.
  16. Southern Motors
    Southern Motors
    I got a bottle of what was labeled 600w (just what exactly it is I don't know) from one of the Model A vendors, when I poured it in the trans it was the thickest goo I have ever seen but it seems to work well and my trans is quiet.
