Some quick bathroom scale measurements; Early Ford 16 x 4.5" 17lb 70's era 15 x 5" 19lb 15 x 8.5" slot 15lb 15 x 8" American Torq Thrust straight spoke 17lb
Some semi-useful information. A rule of thumb: cast iron is 3x as heavy, but 2x as strong so the same part strength-wise the aluminum part will weigh 2/3 as much. Don't compare steel to cast aluminum, because their properties are so different. Compare steel to wrought aluminum.
