Mallory Distributor help.
Discussion in 'The Hokey Ass Message Board' started by Trevwood, Mar 7, 2014.
  1. Trevwood
    Trevwood
    I have recently bought a Mallory Distributor for my Y block (272) and wanted to know a bit more about it.
    For starters it's a YC336HP, searched the web and found nothing!
    I see people with YC311HP, is there much difference?
    Any info will be appreciated, thanks.
    Trev.
  2. vtwhead
    vtwhead
  3. Trevwood
    Trevwood
    Interesting read thanks vtwhead.
  4. GMC BUBBA
    GMC BUBBA
    Trevwood,
    My catalogs show the Mallory 311 as being correct for the 55-56 272 and 292 engines.
    The 336 is shown as a 57-59 312 application.
    There could be a difference in the drive gear, lower end and oil pump drives between the two units..
    I think the Y Blocks used a tang drive, and a couple different sizes of oil pump drives....????????
  5. Trevwood
    Trevwood
    Good info GMC BUBBA thanks.
    I'll be sure to check those areas out before using it.
  6. Trevwood
    Trevwood
    Had some good info come from the Y Block forum that said there is no difference in gears and oil drive shaft between the 336 and 311, so it's good to go. Trev.
