Projects And it begins.....
Discussion in 'Traditional Hot Rods' started by Lowbuckboz, Oct 13, 2013.
  1. firepilot
    firepilot
    I like where you are going. Nice keep it up.
  2. Lowbuckboz
    Lowbuckboz
    Thanks bro! It's coming along. It'll be cool when finished.
  3. very nice! i like it
  4. malibulvr
    malibulvr
    Great looking start, must be nice not digging through all the rust.
  5. Lowbuckboz
    Lowbuckboz
    Very true right there!
  6. Lowbuckboz
    Lowbuckboz
    More deconstruction... ImageUploadedByH.A.M.B.1393038414.510753.jpg ImageUploadedByH.A.M.B.1393038425.337179.jpg ImageUploadedByH.A.M.B.1393038437.946676.jpg ImageUploadedByH.A.M.B.1393038447.904717.jpg
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    you butcher you...:D
    kidcampbell71 likes this.
  8. Lowbuckboz
    Lowbuckboz
    Lol! I use clean butcher knives!!
  9. Lowbuckboz
    Lowbuckboz
    And here is the shifter. Can't wait to shift this thing! ImageUploadedByH.A.M.B.1393109163.725421.jpg
  10. And I admire that!!!
  11. Lowbuckboz
    Lowbuckboz
    V8 clutch setup and a Clings adapter. ImageUploadedByH.A.M.B.1393521872.799547.jpg ImageUploadedByH.A.M.B.1393521893.450891.jpg
  12. olskool34
    olskool34
    You are going to love that trans behind the banger. It was the first thing I did to mine and it was well worth it.
  13. Lowbuckboz
    Lowbuckboz
    Yeah man! I'm looking forward to driving it with that trans!
  14. Lowbuckboz
    Lowbuckboz
    Hey olschool, did you use a stock clutch or the V8 stuff.
  15. olskool34
    olskool34
    I actually am still running the A clutch. I haven't had any issues with it. It pulls good.
  16. Lowbuckboz
    Lowbuckboz
    I'm really wonder if the V8 clutch set up was worth it. Needed the clutch done anyway. It slipped before, the clutch plate was new. Pressure plate was old.
  17. olskool34
    olskool34
    I have heard both pro's and con's about using the v8 clutch. I know it is pricey.
  18. Lowbuckboz
    Lowbuckboz
    I'm hoping I like it! LOL
  19. navyboy
    navyboy
  20. fortynut
    fortynut
    I understand retrofitting juice brakes, and also dig '40 style brakes. Is this a period perfect car? If so what year is the cut-off? I ask because f100 brakes are self-energizing (not sure about f1's). I have driven an ***ortment of jalopies and rods and brakes are like having prayers answered, and certainly the better the brakes the quicker you avoid crashes --- always good. I'm just sayin'. I know you took the backing plates from a revered stash and I may be talking out of school. If so, it is only in the pursuit of less cinch marks in your skivvies. Something rodders who have been there know well. Today's roads are truly fast and furious, pardon the pun, and a nice car needs all the help it can get.
  21. Lowbuckboz
    Lowbuckboz
    I do understand your thoughts on brakes. Anything can happen and good brakes are a plus, no doubt. You do have a valid point. That being said, I am doing a car that will represent the early to mid 40's. The newest part on the car will probably be the hub caps, 46 Ford. Now, I am using a dual chamber master cylinder, not fond of the single.
    As I kid growing up, my dad had a 40 Ford. It was stock, other than the 283 Chevy. He drove it all over with me in the p*** seat with no seat belts and stock 40 brakes. Don't remember any real problems with it stopping. Part of the reason I'm not in any fear of the brakes. I also drive the **** out of my 30 Ford with mechanical brakes. I drive that car as I'll drive this roadster, NOT like my modern car. That I think is the key to this stuff. I can't control the other guy who may pull out in front of me, that holds true no matter what I'm driving. I'll just drive as smart and defensive as I've always have.
  22. x77matt
    x77matt
    Subscribed! If you're taking votes, I vote for the A grill shell, as it goes better with the frame and style.... If you went 32 frame, then I may vote for the 32 grill. Also, they look goofy with an uphil hood line if you don't chop it or lower it over the crossmember a couple inches.
    Great build so far! Can't wait to see more....
    Matt
  23. Lowbuckboz
    Lowbuckboz
    Yes, the A grill shell stays. I dig it with the look of the car!
  24. 3wLarry
    3wLarry
    from Owasso, Ok
    good
  25. Lowbuckboz
    Lowbuckboz
    Start the F1 crossmember this week. I'll update as soon as I have some shots. Thanks for the motivation guys!
  26. Lowbuckboz
    Lowbuckboz
    Well, it's been whittled down and sized. A few welds on it in the corners and I should have a good crossmember. ImageUploadedByH.A.M.B.1394248866.195341.jpg ImageUploadedByH.A.M.B.1394248881.915390.jpg
  27. Lowbuckboz
    Lowbuckboz
  28. fmascioli2@gmail.com
    from CT
    Looking good! Keep doing what you're doing.
    What's your plan for the wishbone? We made up a belly band to support the ball on our coupe.
  29. Lowbuckboz
    Lowbuckboz
    Not sure what I want to use. I have a split pair of 35's and many various years that are not split. May adapt an A yoke to longer bones. I'm leaning towards split because I can tuck them up a little higher. They will not be parallel to the frame, but rather appear almost not split by being close to the cars center line.
  30. Lowbuckboz
    Lowbuckboz
    Just found this in the parts pile! It'll get used. ImageUploadedByH.A.M.B.1394317800.944589.jpg
