Dang-It!
Discussion in 'The Hokey Ass Message Board' started by Greaser Bob, Mar 6, 2014.
  1. Greaser Bob
    Greaser Bob
    Dropped my little plastic speedometer drive gear down inside my 3-speed manual transmission tonight!! :mad:
    1950 Chevy with I believe a 235 in it. Oh, and it's an open drive trans so I'm guessing it's not original as well.
    Where can I get a new one?!?
    Thanks guys.......
  2. Greaser Bob
    Greaser Bob
    Does that rear housing just slide right off?
  3. mechanic58
    mechanic58
  4. Erics53
    Erics53
    from Ohio
    Sounds like a job for the Harbor Freight inspection camera. Drain the trans and go fish in the hole the gear dropped down in??
  5. tfeverfred
    tfeverfred
    Not to make light of your plight, but I had to replace the O-Ring on my speedo sender and thought about this thread. My conclusion was that I'd drop the drive shaft and pull the tail.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Yeah,don't leave it in there. HRP
  7. Greaser Bob
    Greaser Bob
    Yaaaaaaaaaaaaaaay!!!!!!!!!
    Turns out there is some cast webbing that stopped it from falling all the way into the bath/sump area, and I "fished" forever until I got it!!
    Thanks again guys!!!
  8. big bad john
    big bad john
    You lucky duck.......glad you got it out
  9. stimpy
    stimpy
    hmm he has a plastic magnet , I knew someone had one ...
  10. Greaser Bob
    Greaser Bob
    45 minutes of working with two dental pics and I got it!
  11. Beebeebobby
    Beebeebobby
    from Webb City
    Which is cheaper ? Have you fly in with your dental pics next time I have a problem or just get the dental picks? Where do you buy those dingblasted things?
  12. Greaser Bob
    Greaser Bob
    Was probably like ten years ago I found them at some automotive store-wish I could remember the name of the chain!
  13. Engine man
    Engine man
    from Wisconsin
    Most of the local parts stores have dental picks. I grab a couple more every time I stop in.
