Technical adapting later ford flathead to early trans
Discussion in 'Traditional Hot Rods' started by 3desotos, Mar 9, 2014.
  1. 3desotos
    3desotos
    i am putting together a 52 flathead v8 and a 1939 trans. i have a cast iron adapter to mate the two. it bolts fine to the back of the engine, but the dowels do not line up on the adapter to the trans. when i put one dowel in its hole, the other is about an 1/8 inch out too much. are there different adapters? i had tried a spare case i had,and same thing happened. adapter and dowels look fine. no cracks,and dowels look straight. any help would be appreciated. thanks..
  2. Get a stock bellhousing for '49-'51 Merc.
  3. ned5049
    ned5049
    I've got a 49 Merc bellhousing, if that will work for you.
  4. yard man
    yard man
    Are you using the removeable bellhousing / adapter from the F1 pickup? Or aftermarket?
  5. 3desotos
    3desotos
    i bought it here years ago. not sure what its off of.
  6. V8 Bob
    V8 Bob
    The pictures below are the '48-'52 truck cast iron 1/2 bell.
  7. 1941coupe
    1941coupe
    that should bolt right up iv done dozens,is the clutch aligned? if not it will not let the trans go in straight .the trans must be ****ed it must be even all away around
  8. 3desotos
    3desotos
    i am in the middle of mock up stage. there is no clutch in either of the ******s. they are just cases.
  9. 3desotos
    3desotos
    that looks like the one i have.
  10. Ric Dean
    Ric Dean
    from Central NY
    .. Pro Race engine builders center the bellhouseing from the center of the flywheel with a Dial Indicator. To correct any variations they use ‘offset dowels’ which are available, this also is a good way to get rid of clutch chatter.
  11. BillM
    BillM
    Are there dowels in the block that locate to the adapter?
  12. walter
    walter
    49 merc make certian you get the starter plate and flywheel ***emble. aqll just bolts togeather
  13. gearhead1952
    gearhead1952
    That setup will work. Have that setup in my 34. What do you mean an 1/8 inch out too much?
  14. George/Maine
    George/Maine
    If the half bell housing bolts to the block you may have a 6 cylinder trans case they are not the same as v8.
  15. gearhead1952
    gearhead1952
    Not true. The trans are the same.
  16. V8 Bob
    V8 Bob
    The '41-'48 round pattern 6 cyl. trans case is different than the V8s.
  17. flatoz
    flatoz
    How about some photos? might help people guessing on what your working with and allow them/us to give you actual, factual information on what to do.
    At the moment were all just guessing at what you need to do and what you have.
    A couple of photos will help us help you.
  18. George/Maine
    George/Maine
    I have a bell housing like post#6 and measured the pins center to center and little less then 12 5/16" when drilled may have been 12.300
    The 6 and v8 are not the same case.
    measure the trans case.
    I also think the bolt pattern is not the same.
  19. 51504bat
    51504bat
    6 cylinder hogs head is different than the V-8. Also, the Merc stamped steel hogs head won't take an 11 inch clutch where a cast truck hogs head will. Don't ask me how I know.
  20. gearhead1952
    gearhead1952
    You guys are going to have to prove it to me. According to Vanpelts book there were only three cases 18-7006, 48-7006 then 78-7006. I've taken quite a few trucks apart with 6s and 8s and only the bellhousing to block was different. Got a part number?
