Technical Threaded Dust Covers on Ford Axles. What years?
Discussion in 'Traditional Hot Rods' started by sandmountainslim, Mar 10, 2014.
  1. I went to replace the dust caps on an old Ford I Beam I am messing with and discovered rather than pressed in the caps screw in (female end on the cap). I was told when I bought the front end it was a 47 or 48 but a guy at the parts store told me the threaded dust caps were only on 42 and down Ford models. What is the truth of the matter?
    Thanks.
  2. fordor41
    fordor41
    My '41 had screw on covers, round spindle brake mount.
  3. Halfdone
    Halfdone
    My experience has been that hub inside drum has screw in caps, and hub outside drum has push in caps
    But thats just my limited experience
  4. verde742
    verde742
    I remember "42 and earlier had screw in caps.
  5. 1941coupe
    1941coupe
    my 41 has screw in caps
  6. 19Fordy
    19Fordy
    1940 Fords have screw in caps also.
  7. the axle doesn't have the extra hole so I know its not a 48 and the caps screw in so I am gonna guess from the length and shape its probably early 40s. I was told by a previous owner it came from a "48 coupe" dragged out of the woods on Lookout Mountain. My best guess is he probably mistook a 41 for a 48.
  8. highboy
    highboy
    from marin
    Also keep in mind the type of dust cap...or year of drum... does little to help identify the year of the I beam they all interchange therefore 48 drums don't mean 48 Ibeam. And i have 41's with the inner hub with a press cap. so it might be 39 40 only with the threaded cap
  9. I used this chart which is floating around to determine it is not a 48.
    The 48 had an extra hole which the others lack.
  10. Here are the backing plates if that is any clue to it's age. It is mounted under a trailer at present.
  11. Jimmy2car
    Jimmy2car
    from No. Cal
    39-41 type, I think
  12. Thank you. You are likely correct.
  13. pasadenahotrod
    pasadenahotrod
    from Texas
    Since all the base hydraulic brake parts are interchangeable between the 39-41 and 42-48 brake setups you can't guess which part you have by IDing just one part.
    I've dismantled many 28-48 Fords and found many with mixed backing plate brake assemblies, spindles, hub/drum assemblies.
    Spindles: 37-41 round flange, 42-48 square flange, or earlier mechanical brake spindles
    Backing plates: 39-41 with shoe lower adjustments, 42-48 with fixed lower shoe studs
    Hub/drum assemblies: 39 with wide five pattern drums, 40-41 with 5 on 5.5 pattern drums mounted over hub flange, 42-48 with 5 on 5.5 pattern drums mounted under hub flange
    Hubs: rear using 28-36 big cage wheel bearing or rear using37-48 small cage wheel bearing
  14. 48-760
    48-760
    from OH
    I have a inside hub like the 40-42 drum that takes the pressed in dust cap. It would be my guess it is from a very late brake drum made for the 40-42 maybe by an aftermarket supplier of drums. The Ford green parts book list the threaded cap B-1139 for 31-35, 68-1139 for 36-45 & 51A-1130 (no threads) for 46-48.
