Slammed the '31 Ford Coupe! Sweet and Low Down!
Discussion in 'The Hokey Ass Message Board' started by Elrod, Feb 8, 2009.
  1. Jimmy2bottle
    Jimmy2bottle
    Its threads like these that make me wanna mess with the stocker I picked up... I love the stance and the 3" chop looks just right.. nice proportions all around
  2. Anderson
    Anderson
    Jason......I'm sorry. Hahahaha :D
  3. Aman
    Aman
    from Texas
    Keep it coming you're doing a great job here. We need more fenders on A's. I think they're half the car and make them look much better and the way Henry wanted them...no pun intended...them..:p
  4. hudson_hawk
    hudson_hawk
    wow, looks awesome. great job!
  5. Hot Rod Michelle
    Hot Rod Michelle
    Nice looking coupe.
  6. Eightydeuce
    Eightydeuce
    That is perfect looking in my opinion. It looks good in the before picture as well.
  7. seatex
    seatex
    Damn! Now you got me thinking about fenders!
    :eek:
  8. HOT ROD DAVE
    HOT ROD DAVE
    now i see what mine will look like without a chop........ack!!!!
    im taking 3 out of her
    looks great lowered
  9. pecker head
    pecker head
    How much did the T spring lower the A ? And were the eyes reversed ?
  10. Elrod
    Elrod
    The coupe earns some patches.
  11. Rokkern
    Rokkern
    from Norway
    Great inspiration !
    I Have a tudor stocker, just bought it and being new to hotrods this came up searching for drop and mechanical brakes.
    Almost making me wan't to keep the fenders ...!
    TheeKeithAllen likes this.
  12. brady1929
    brady1929
  13. pat59
    pat59
    Sweet ride. I wanna build one just like it. :)
    -Pat
  14. JoeyP.
    JoeyP.
    3340
  16. ChefMike
    ChefMike
    what a great ride ! nicely done
  17. Deuced Up!
    Deuced Up!
    Great stance! We may all have to hate you for a while...but it will wear off sooner or later! Killer vibe to that car.
  18. Big Mac
    Big Mac
    Looks really good man. I dig it just how it is...
  19. cody1958
    cody1958
    from wichita ks
    Great looking car
  20. A Rodder
    A Rodder
    Forgive my ignorance,
    When you say he stretche dropped the axle, is it 4" lower than it was stock, or is the distance from the top of the pin boss to perch hole 4"?
    I am thinking I am going to do this. But want my terminology correct.
  21. Elrod
    Elrod
    When an axle is dropped the normal way, it gets narrower. The process makes the spindle closer to the wishbone boss.
    Oakie joes will drop the axle but also pull the axle longer so that after the drop is finished, the track width is the same as stock, but the car sits lower.
  22. 28'FordSportsCoupe16
    from Minnesota
    You said you had a T rear spring out back, what brand is it? Where did you get the spring? And besides having to remove some leaves did you have to do any other modifications to the spring to install it and get it sitting where it is now?
  23. Elrod
    Elrod
    The T rear spring brand is good ole' Ford Motor Company, circa 1926-ish. Found it at a swap meet. Pretty readily available around here. I just removed the top smallest leaf and then just swapped it out with the stock A spring.
  24. DrJ
    DrJ
    Good question.
    I'd like to know the answer too.
    I've never seen an understandable answer, anywhere.
    And measured form the top of the spindle or the bottom or somewhere in between?
  25. Elrod
    Elrod
    Stretch drop maintains the original width within 1/8 of an inch, while a conventional drop shortens the axle approximately 3/4 of an inch per side. This tighter curve in the axle allows less room for the stock steering arms. This is why a lot of people heat and drop their steering arms. If you don't have a torch, the stretch drop is easier to install and allow for steering.
    NORMAL DROPS
    MY (Oakie Joe's) STRETCH DROPPED AXLE
  26. Uncle Bob
    Uncle Bob
    from Salado, Tx
    And, for mechanical brake apps the stretch drop also maintains the proper mount distances for the actuator cross shaft as in the bottom pic above. (been mentioned before, but since we're restating......)
  27. Elrod
    Elrod
    ^^ Yup yup!
  28. 1knuckle
    1knuckle
    from arizona
    How did you spread the T spring to reinstall it? When I took my A spring out today it wanted to break my arm when I tapped the shackles out. I picked up a 8 leaf complete with the cross member that I will install in the 29 cc pu. You said you took out a couple leafs but used the upper short one from the A spring. i ***ume you did that so it fits in the a cross member tighter
  29. 1knuckle
    1knuckle
    from arizona
    Oh, and Oakie Joe did my front axle too. Hey Joe. If you have any hotrod questions he will answer them for you, he has been hot roddin for along time.
  30. squigy
    squigy
    from SO.FLO.
