Projects 25 T roadster gow job build
Discussion in 'Traditional Hot Rods' started by olskool34, Sep 13, 2013.
  1. olskool34
    olskool34
    Also a few more things, I hate the grill shell apron, just hate it. I am going to take it off and start over ( I tend to do that) using the upper part of another T shell. I also got the ***le for it so she is now legal! Time to get rolling.............
    Dannerr likes this.
  2. Rogi
    Rogi
    Sweet! This is the most bad*** T ever. So clean and simple - no bull ****!
  3. olskool34
    olskool34
    Aaron, you are too kind! Thanks!
  4. timothale
    timothale
    23 T touring wood blue prints
    A while ago I said I had some prints that I used for doing the wood in my original restoration an a T touring. The prints were done years ago by Mel Miller in oregon. He since p***ed away but his daughter is now handling the T business. You can google mel miller model t or send a SASE to Jennifer-model T, 620 4 Th Ave SE, Albany, Oregon 97321 </ARTICLE>
  5. fab32
    fab32
    I'm really liking this build and it looks like your getting down to the short strokes. Your going to have a ball with this thing over the summer. Kinda make you forget this brutal winter we're FINALLY starting to come out of.
    Frank
  6. gwhite
    gwhite
    SUPER MODERATOR
    Wow, looks great! Dig the birch floorboards!
  7. Jungle Jalopy
    Jungle Jalopy
    I am a huge fan of this car. T Fever! It's sweepin' the nation.
  8. Nailhead A-V8
    Nailhead A-V8
    Too many questions? lol Thanks bct but I've pretty much decided against wood on this one
  9. olskool34
    olskool34
    My wood was almost all gone so that is why I went with steel. The wood kits are very pricey for these damn things. Thanks guys for all the kind words, I really appreciate it!
  10. 29pu
    29pu
    Maybe try low radiator style apron on it.They aren`t near as big.
  11. bct
    bct
    you don't understand .you use plywood strips on the outside to support and define even curves while you build the inner structure. plywood curves nice and even, not like lumber. you can set door gaps . level body lines . I have the exact same pieces you have for a 25 t roadster and I will start with a sheet of plywood for the bottom platform , with a centerline or better yet a grid, and then screw strips of plywood about 3" wide and straight along a body line from the inside to level , square and plumb my panels. what you do to the right side you do to the left. I built my touring like this with only the top half of the car and only the front half of the subframe. like I said .p.m. me . here are some pics of the first time I did it with clamps . the last time I used screws and spaced the 1/2" plwood away from door beads and hinges. I marked the left strip exactly the same as the right one and made the body symmetrical. the 26 /27 is smooth compared to pre 25 so spacer would be needed
  12. olskool34
    olskool34
    Ok, got this in the mail today. I am going to mess around with it a bit and see if I can make the bottom of my existing shell out of the top of this one.
    Dannerr and brEad like this.
  13. gwhite
    gwhite
    SUPER MODERATOR
    Dig it! Great idea. Here's a ****py photoshop;
    Outback, Dannerr and brEad like this.
  14. flatheadgary
    flatheadgary
    from boron,ca
    now that grille shell looks wicked kool!!
    loginrc likes this.
  15. olskool34
    olskool34
    THANK YOU!! That is exactly the look I am going for!
    Dannerr likes this.
  16. gwhite
    gwhite
    SUPER MODERATOR
    No sweat, I'm loving this build!
    You planning on pounding out the embossed "Ford" script? It might look better that way.
  17. Jungle Jalopy
    Jungle Jalopy
    Subscription please.
  18. olskool34
    olskool34
    Yeah that was my initial plan. My wife told me to cut it out and put it back in upside down. Don't know about that, might be too much.
  19. flatheadpete
    flatheadpete
    from Burton, MI
  20. olskool34
    olskool34
    It was 48 today so I hurried home from work and got in the garage to work on the shell. After some mock up and measurements, I decided to make the T shell mount like an A shell does and cut off the feet. Since I am running an A radiator, the brackets are already there to mount to the side of the windlace channel. This is what I came up with and I am very stoked about it. Exactly the look I was envisioning. Thanks Gary for the photoshop!
    What I cut off each shell.
    After I welded up the two.
    On the car.
    DylanHill1931, Dannerr and brEad like this.
  21. olskool34
    olskool34
  22. captainjunk#2
    captainjunk#2
    looks awesome good job ,
  23. bct
    bct
    looks great and unique!
  24. 26 T Ford RPU
    26 T Ford RPU
    Man that looks sweeeeet!! JW
  25. Anderson
    Anderson
    looks great.....nice idea!
  26. olskool34
    olskool34
    Aaron "Rogi" suggested that maybe I should put a crank hole in it in case my battery ever fails. I thought about it and I liked the idea too. I had an old crusty 28 A shell so I cut the hole and cover out of it and put it in the T shell.
  27. 26 T Ford RPU
    26 T Ford RPU
    Just keeps looking better and i love the tie bar position.JW
  28. sadsack
    sadsack
    love it
    sadsack
  29. olskool34
    olskool34
    Thanks for the comments guys, I think the car needs to sit a tad lower the more I look at it. I think I am going to get both front and rear main reversed eye leafs. I think then it will be where I want it. Also got some rear shocks today that I think will work. I had a set of delco's for it but I have some houdailles on the front so I wanted a similar type for the rear. Going to link them to the axle housing.
    DylanHill1931 likes this.
  30. olskool34
    olskool34
    I was looking in a T speed secrets book and I saw a few that were running knock off's, some looked only like dress up caps. I really liked the look so I searched and searched but found none. I contacted a guy on the fordbarn that used to repop them and he said he used to make them for the late T wheels and model A's but he has long since retired. I found these for 12.00 and thought maybe I could make them work. No idea what they are off of. This is what I did.
    Took some aftermarket A caps and cut them in half. Cut some slits to open it up.
    As you can see, the A cap fits tightly and centered in the recess of the knock off.
    Filled up the recess with epoxy and pushed the A cap in and let sit 24 hours.
    And this is what they look like on the A wheel, and the mount just like a stock A cap. Think it will give the roadster a racey look.
