sanderson no gasket headers
Discussion in 'The Hokey Ass Message Board' started by bulletproof1, Mar 15, 2014.
  1. bulletproof1
    bulletproof1
    from tulsa okla
    I have yet to get these things to seal. am I the only one? s10 v8 swap headers on my 53 ford car.
  2. mad mikey
    mad mikey
    I had the same problem with a set from them. Used SPEEDWAY extreme gaskets and sealing problem was solved. And SPEEDWAY says they are re useable = GOOD LUCK! Mikey,
  3. Vergil
    Vergil
    I have two av8's with Sanderson headers and haven't had a leak problem, a friend also has two av8's and no problem with his either. I use just a smear of high temp rtv on the sealing area when installing.
  4. bulletproof1
    bulletproof1
    from tulsa okla
    the reason I bought them is because of the good reviews..
  5. NickJT
    NickJT
    from S.E. PA
    My $0.02 is two Sanderson header installs with no gaskets other than their high temp goop and no leaks in a couple years.
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    I have Sanderson Limefires on my 27 and have always used header gaskets on them. Every few years they dry up and crack and I just replace them, but I get no leaks when the gaskets are not aged.
    I know their ads say no gaskets needed, but I am just old fashioned.
    Don
  7. captmullette
    captmullette
    use red atv on heads let set for a few minutes then bolt on headers, never had any leaks and I run mine wide open for a 1/4 mi at a time.....
  8. themoose
    themoose
    Never had a problem using the same process as the guys above^^^^^
  9. dirtbag13
    dirtbag13
    Yep red rtv on all my headers , never had a leak and no ugly gasket hanging out
  10. seadog
    seadog
    what Big-Foot said...worked for me. Use a liberal bead of RTV.
  11. FOURTYDLX
    FOURTYDLX
    No gaskets,red atv, no leaks,6 years
  12. gimpyshotrods
    gimpyshotrods
    Countless customers, RTV, no gaskets, no problems.
  13. tfeverfred
    tfeverfred
    Seems like Sanderson needs to updated their ads.
  14. bulletproof1
    bulletproof1
    from tulsa okla
    im done.. put the extreme seal gaskets on..not much better, they are coming off, hedman fenderwells going back on..
