Projects 403 Olds engine
Discussion in 'The Hokey Ass Message Board' started by LoneSpar, Mar 16, 2014.
  1. LoneSpar
    LoneSpar
    from Pacific NW
    Is a 1977 403 Olds desirable? I have one on a motor stand in my shop. Was going to put it in my 56 Chevy panel truck but decided to keep the SBC in it.
  2. ***Area-51***
    ***Area-51***
    from Ohio
    some olds guy like them....some of the mid 70's Trans Am's came with them so TA guys except them...definitely desired by some, don't throw it away...
  3. '51 Norm
    '51 Norm
    from colorado
    Like everything else, some folks like 'em and some folks don't.
    I would keep it just to have another "different" engine laying around. But then I am an engine junkie.
  4. LoneSpar
    LoneSpar
    from Pacific NW
    I need to clean up my shop, but I did think about doing a rod project.....
    Sent from my BLU Life One using H.A.M.B. mobile app
  5. They are a castrated 455 aren't they? I think GM was trying to make a more fuel friendly big motor, by destroking the 455, I've heard that by destroking, they destroyed the strength of the 455, namely big torque numbers
  6. 24riverview
    24riverview
    No, actually a bored out 350, a "small" block Olds motor.
  7. powrshftr
    powrshftr
    Negatory Steve!
    The 403 got a bad rap from being a lo-po s****** alternative to the Pontiac 400 in Trans Ams,but it's a big bore,short stroke 350 Olds on steroids.
    (in my opinion the Olds was by FAR the finest of all the 350's).
    Anyway,with a decent cam,compression and carb,these things make a ****load of power!
    A buddy of mine ran one in an o/t trans am in highschool,and there were VERY few cars around town that would give him any trouble.
    Scott
  8. stimpy
    stimpy
    its what the T/A guys call the window block , something that had to do with the way the mains were designed ( never paid attention as I ussually was pulling them for a 400 or 455 Poncho ) , OLds guys treat them like the Ponitac guys treat the 301 , some like them, ALot dont, they do not like revs , but they make lots of bottom end and cruise torque so you don't need them most of them used 2:40 gears with them .
  9. mechanic58
    mechanic58
    The worst part about a 403 is the block - they are "lightweight" castings. They have windows in the main webs actually. From a geometry standpoint they are great engines with a lot a potential - but they just aren't strong enough to handle big hp. The second worst part about em is the heads - find an early set of 350 heads, #5 or #6 and put those on and you can really wake one up. I've always like a small block olds....I just never cared for the accessory drives they have. I'm using a '70 350 in the t-bucket I'm building right now, but I am making my own accessory drive.
  10. blue57ford
    blue57ford
    I overhauled a TH350 that was behind a 403 in a Trans Am last year. I was surprised by how peppy it was. It had no problems moving that car.
  11. stimpy
    stimpy
    from what the olds guys were saying if you get rid of the factory manifolds and put headers or a true dual style manifold they make some power , the goofy 2 into one manifolds are what held them up .
  12. COOP
    COOP
    Had a 403 given to me 'cuz the guy that owned it didn't have any use for it, but didn't wanna toss it. It sat in my barn for a couple of years before I stuck it in a T Bucket. Factory rated at 145 H.P. Found out its a torky 'lil ****. Smolders the tires right thru 2nd gear. It came with a bad 400 turbo that I'm gonna have to change. It is all stock with a Q-junk carb. all I did was fabricate a set of lakes type headers with no mufflers. With it's low compression it ain't all that noisy. Kinda like fartin' in a sock. Seeing as there is no weight to haul around I think it will hold together. I'm not an Olds lover, but I was pleasantly surprised how it ran and managed to keep cool with a little 2 core T type radiator.
  13. 61falcon
    61falcon
    good heads and a mild cam it will be a good engine and its way cooler than a belly ****on.
  14. 26Troadster
    26Troadster
    they are over bored 350's with lightened blocks, but had the best factory rods in a small block. i have seen some good ones over the years.
  15. LoneSpar
    LoneSpar
    from Pacific NW
    Well I am going to have to sell it now. Getting a 56 Vette engine tomorrow.... Going to been my motor stand back!!!
