Technical 1933 Ford Aftermarket X-Member Options ?
Discussion in 'The Hokey Ass Message Board' started by Tin Lizzie, Mar 18, 2014.
  1. Tin Lizzie
    Tin Lizzie
    from Ohio
    Hello Hambers,
    I'm looking for options for a traditional looking X-member for a 1933 Ford Frame as the original is long gone and the frame has been boxed. Any help you guys can give me would be greatly appreciated ?
    Thanks,
    Mark
  2. david363
    david363
    from Texas
    I bought mine from Ch***is Engineering Inc.Nice part to replace original.
  3. Pewsplace
    Pewsplace
    Ionia Rod Shop offers one as does the aforementioned CE. Both work well in stock frames.
  4. ff1930
    ff1930
    from lapeer
    RJ ENTERPRISES sells one original style construction mounts in same position as original but modified to provide additional center and trans mount clearance
    Tom Bay 620-441-0032
    Never used one but looks wider in the center for big transmission
  5. Tin Lizzie
    Tin Lizzie
    from Ohio
    Hey thanks guys for the suggestions can anyone else please chime in with their thoughts ????
  6. Any pictures of the one from RJ Enterprises?
  7. Tin Lizzie
    Tin Lizzie
    from Ohio
  8. It's pretty easy to fab up the center channels. And that's the way I would go.
    If you need/ want the double inside front and rear or the U bracket that's gets a bit more involved.
  9. Pewsplace
    Pewsplace
    He is right. I ended up having mine bent up at a large sheet metal shop with a hydraulic break. I furnished the 10 ga metal and for $45 he made me two 8' channels. I then bent them to shape and drilled the holes. Several threads on here show the process.
  10. ff1930
    ff1930
    from lapeer
    The best I can do for more info on rj enterprise center x was to photograph and post
    maybee this will help
  11. Pewsplace
    Pewsplace
    These look good in the photo and price right.
  12. Tin Lizzie
    Tin Lizzie
    from Ohio
    Hey thanks for all the input anyone else ???
  13. Tin Lizzie
    Tin Lizzie
    from Ohio
    Anyone else ???
  14. X38
    X38
    I think you're optioned out as far as aftermarket goes in answer to your specific question. Beyond that it's a case of fab your own or have a shop do it for you.
