Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. Evilfalcon1961
    Evilfalcon1961
    from Ma
    selling my n.o.s. cal custom spider caps too. they are dusty right off the shelf [​IMG]
  2. redzula
    redzula
    Sent you a PM
  3. longroofCOMETment
    longroofCOMETment
    this is a local car in my area, I hope to get more, an better pictures of it this year.
    another PNW car I like quite a bit, not sure if the owner is on here or not, but at any rate
  4. AndrewnTX
    AndrewnTX
    from Plano, TX
    Found some Falcon motor compartment shots to share...
  5. DAGONITWIT
    DAGONITWIT
    from NO VA
    Hey Longroof, are those intake pipes copper?
  6. longroofCOMETment
    longroofCOMETment
    not all too positive on that one, at first I thought it had been chromed and then sanded off, but it used to just have like a smoked clear powder coat on it so it may be.
  7. 1971BB427
    1971BB427
    from Oregon
    I remember seeing that one at Jubitz, but haven't seen the other one around.
  8. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
  9. 63 1/2 peregrine
    63 1/2 peregrine
    ????? i bought my 63 1/2 sprint with new windshield installed but chrome trim came in a box. Does windshield have to b removed to install chrome. Any help is appreciated
  10. fca2572
    fca2572
    from Texas
    Unfortunately the window has to come out to install the lower piece of chrome trim. The sides and the upper chrome can be installed after the gl*** is in
  11. 63 1/2 peregrine
    63 1/2 peregrine
    Thanx for reply. info much appreciated. was afraid that was the case. hate to pull a new shield but gotta have chrome installed. building a 60's g***er. I enjoy the site. keep the falcons flying.
  12. longroofCOMETment
    longroofCOMETment
    yea the other is down here in central Oregon
    and you are correct on the green one, that's where I took the picture.
  13. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    So I had a persistent intake coolant leak that I decided was the fault of the Fel-Pro 1250 Print-O-Seal intake gaskets that I've been using on various SBF's for many years without a problem...
    As it turns out, my trusty Weiand street fighter intake was bent....warped .008 in the middle.
    So I figured it was time for a change and got an Edelbrock 7521 air gap.
    The Edelbrock intake gaskets su****iously looked a lot like the Fel-Pro 1250 Print-O-Seals.
    With an Edelbrock logo.
    Now I'm just waitin' for the glue ta' dry...
    It's supposed to be in the high 60's next week. I think January might finally be over on the right hand side of the country..
  14. AndrewnTX
    AndrewnTX
    from Plano, TX
    Nice motor! I know what you mean on vacuum leaks, chased one for a long time myself.. don't miss those days!
  15. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I should'a been more specific- it was a coolant leak... I'm laffin' here.
    Not at you though; me.
  16. Evilfalcon1961
    Evilfalcon1961
    from Ma
    anyone looking for a radio delete for their 62-63 futura? new old stock piece
  17. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Just sent you a PM...
    Posted with an IBM Selectric
  18. falconeer
    falconeer
    Evil, Sent you 2 PM,s on the delete plate please ck.
    Thanks: Butch Evans
    Thomasville NC
  19. Bigcheese327
    Bigcheese327
    Is anyone running their stock '60-'64 FM2 column shifter with an AOD transmission? I read elsewhere that the C4 detent sold by Falconparts.com will work with an AOD, but I didn’t find any more details. I’m having trouble finding a T5 for my ‘62 and since I have all the automatic parts, I’m researching the possibility of running an AOD behind the 250 instead.
    Thanks for any help!
  20. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Yup, I'm currently running an AOD with the C-4 detent plate on my column shift 63. Works fine, it's just a little fiddly to change with the square headed bolts while working against the spring pressure for the column linkage inside the tube. I've got a picture some place....
  21. Bigcheese327
    Bigcheese327
    Great! This was explained to me by another fellow who indicated that his 1983 AOD was set up so that one could not manually select second gear - is that the same for yours?
    Thanks!
  22. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Well, kinda' correct- with the Cruise-O-matic detent plate, it's impossible to manually select the AOD's 2nd gear (on an AOD, this is first gear until it shifts into second...thus the infamous "AOD shuffle" on floor shifters)...
    It'll work fine with the old detent plate, you just can't manually select any gear lower than third...
    You'll also have to make some sort of linkage- My 63 had a half *** conversion when I got it- I ditched most of the linkage that was on the trans but saved some of it:
    I'll spare you the usual TV cable/pressure warning....
  23. Bigcheese327
    Bigcheese327
    By "old detent plate" you mean from the FM2? Giving you P R N O D where the FM2 gave you P R N D 1?
  24. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    With AOD-
    Original plate gave me P R N O/D 3
    C-4 detent plate gives me P R N O/D 3 2
    I never select anything other than O/D anyway-
    I've got a trick Silver Fox constant pressure valve body, 2400RPM stall converter, Trans-Go governor and a bunch of heavy duty **** in my AOD.
    More info here:
    http://www.jalopyjournal.com/forum/showthread.php?p=8656081#post8656081
  25. Bigcheese327
    Bigcheese327
    Thanks again. Sorry for the dumb questions. I've never done much studying about automatics until this week.
  26. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    No sweat, dude. It was hard for me to wrap my head around the fact that there is no manual 1st gear select on AOD's.
    Go over to "Click Clack Racing's" forum for everything you ever wanted to know about Ford automatic overdrive transmissions but were afraid to ask.
  27. Falcon61wagon
    Falcon61wagon
    from Indiana
    Has anybody tried to eliminate some of the steering wheel play in their falcon?
  28. 1971BB427
    1971BB427
    from Oregon
    Yeah, rebuild the steering arms, ball joints, etc. to tighten it up, and then adjust the play in the steering box. If that doesn't do it, it probably needs a steering box rebuild or replace.
  29. need louvers ?
    need louvers ?
    Actually, I have found the best place to start is almost always with an idler arm rebuild kit. It has a rubber bushing that I firmly believe about half of were bad before they left the dealer show room. The kit costs about 15.00 at any parts wholesaler.
  30. oldcarguygazok
    oldcarguygazok
    from AUSTRALIA.
    I've been looking for a 60's sedan delivery for some time now and fortunately found one,the aussie deliverys don't have the long doors,where the American models do I'm a big bloke and need that extra space.I intend to do a few mods,my q/s is,will the convertible door bolt up and will the rubber seal on the conv/top mate up with the door frame on the delivery,thanks for your time and hope you can help ,Gaz!
