Technical 1960s What? Fender skirt quandary.
Discussion in 'The Hokey Ass Message Board' started by REVEREND JAKE, Mar 18, 2014.
  1. Hopefully someone will have an answer for this ditty.
    I recently purchased a set of skirts that were labeled for "1964 Ford Galaxie 500 & XL Fender Skirts," but when I clamped them to my car, a 1964 Galaxie XL 500, they did not fit.
    I compared one skirt to a 1964 Thunderbird (the last image) and it pretty much fit the opening, only the body line was different and the skirt hooks forward a bit.
    Any ideas? Even in the Ford family?
  2. Squablow
    Squablow
    Anything stamped into the lip along the bottom?
  3. Not that I saw. But the insides still have surface rust on them. I can't check because I left the skirts in Dallas.
  4. arkiehotrods
    arkiehotrods
    Rev. Jake! How are ya? Good to see you posting something! Give me a few minutes and I'll be back with skirt i.d.
  5. It's been a while! Thanks!
  6. 63Compact
    63Compact
    Not flat enough across the top to be Fairlane. Good luck
  7. gasmanm01
    gasmanm01
    I have a stainless set that looks like those and can't figure what they fit
  8. R Pope
    R Pope
    '63-64 Merc? They are more "swoopy" than the Fords. I have both, will compare them later today. BTW, some Merc skirts were shiny.
  9. BUHOG
    BUHOG
    clean the bottom edge of both skirts. there should be letter and no. ( if they are foxcraft C 60 chev-1960 b-65 buick 1965 ans so on
  10. R Pope, I looked around on Google Images and think the 1964 Mercury Marauder looks pretty close, but I can't tell if the front of the skirt hooks forward.
    I hope to find out more when my buddy Mark X cleans up the inside of the skirts for priming. Hopefully there will be a visible stamping.
  11. Here's a side profile of the Marauder. Looks pretty close.
  12. Side by side.
  13. Does that look the same to you guys? Chime in.
  14. F-ONE
    F-ONE
    from Alabama
    Looks a lot like what I had on a 62 Galaxie so could be 61-2 Ford.
