Sunday models
Discussion in 'The Antiquated' started by milo1303s, Mar 16, 2014.
  1. chevy57dude
    chevy57dude
    Ratroy - you really took me back with the trail bike. Built the kit ages ago because the Yamaha was my dream bike. Still want one.
  2. Cool! Now I can subscribe instead of going to search every Sunday to find the latest and best. :cool:
  3. rusty1
    rusty1
    wheels/tires from the Monogram Lil Coffin kit, about the only thing I like from that kit other than the Hemi....those wheels/tires look good on anything!
  4. wojojo
    wojojo
    Bumping this thread to Sunday 3-23 too keep the flow going. Someone already started another weekly thread again. Please post new stuff here.
  5. 2002p51
    2002p51
    Finished this Revell '57 Ford.
    The Holmon-Moody decal on the front fender is a hint at what's under the hood:
    A 429 NASCAR engine!
  6. southpier
    southpier
    from northeast
  7. 2002p51,
    That's nice work! What kit is that?
  8. cdansie
    cdansie
    Thought I'd better move this to the right place
    Hi all
    I recently finished this 33 Willys using a stock height resin body from Ed at Drag City Castings.
    I used an old floor pan/ch***is from my spares box and an engine from one of the Revell 32's with a twin Predator Carb manifold.Not shown in the pics are the headers and the slightly modified exhaust system from the Rev 32 kit
    The ch***is was cleaned up and unwanted holes/mounts etc were filled or removed. A flat crossmember was added to the front for the transverse spring
    Front and rear ends are also from a Rev 32 kit. I shortened the rear radius rods for the 32 rear end and added Rat Roaster wheels and tires. The 32 rear end is unmodified.
    The dash was smoothed and a photo-etched gauge panel added. I had to put in a small transmission tunnel to clear the gearbox. Seat is cut from the Speedwagon floor panel and scribed Evergreen was used to try to match the pleated seat pattern.
    The body needed only minimal cleanup but I had to spend a lot of time t******* and gringing to get the front fenders to line up with the running boards - I dry fitted all the parts before painting but found that during ***embly the ch***is pushed the running boards out when I put it up into the body so I had to go back and re trim.
    I added a small filler panel between the lower rear fenders This was made by widening a Speedwagon gas tank cover use (i used 2 cover to make one longer one)
    Paint is Testors Gloss Yellow
    Chris
    quick85 likes this.
  9. john mullen
    john mullen
    my old drag car. the model was given to me by my son for a Christmas present
    OLE442 likes this.
  10. 2002p51
    2002p51
    Thank you, the basic kit is Revell's '57 Ford Custom, the engine is from a Polar Lights NASCAR Torino kit and the wheels and tires are from a Revell '32 Ford kit.
    Atwater Mike likes this.
  11. wojojo
    wojojo
    Not a custom (yet) but here's an old 1/87 scale Ford panel made by Varney back in the 60s. I've got a couple more of these somewhere I think, but this is the only one I found so far. They were molded in clear plastic with black wheels so you could paint them any way you liked.
      30.7 KB
      28.7 KB
      40.5 KB
  12. oldschool55
    oldschool55
    Hope this is the right spot to post this. Just finished a 1/8 scale roadster, converted a deuce to a '31, 1955 Olds for power. Based on a real one, from 1963.
    camcrusher and don colaps like this.
  13. LiveWire64
    LiveWire64
    [​IMG] This is the last model I worked on. Started it in 2009. Is a 1949 Ford Coupe. Need to get back on it,but life's been in the way a lot lately. Brad
  14. Oldshool55,
    That's impressive! 1/8 scale is fun and intimidating at the same time.
    It's big and easy to work with, but the pressure is on to create realism.
    Job well done.
  15. wojojo
    wojojo
    Love the '57 Chevy frontend on it. Hope to see it finished someday.
  16. Critical Mass
    Critical Mass
    LiveWire, are you trying to make a Kaizer? Cool idea! Also, did you know that bleach will remove the chrome from the bumper?
  17. ratwasp
    ratwasp
    ImageUploadedByH.A.M.B.1395612188.060549.jpg ImageUploadedByH.A.M.B.1395612213.001739.jpg
  18. wojojo
    wojojo
    Mockup of a Lindberg '64 Dodge 330 I'm working on. Wheels and tires are Pegasus.
  19. bigern007
    bigern007
    HEY.......Very,,Very nice models guys.
    Thread gets better every week.....thanks..:) :) :) big ern
  20. LiveWire64
    LiveWire64
    I am just building a custom. Thought I would use the 57 Chevy front pieces and the side body lines near the door.
    I do know about bleach,but thank you.
  21. Kit Bash
    Kit Bash
    Subscribed to this ***le " Sunday Models " ...'nuff said.
    Got some new resin from Ed Fluck.
    (contact Ed Fluck lowcab36@epix.net 570-289-4345)
    '36 Ford louvered hood/sides/trunk.
    I have a thing for '36 Fords and I just
    had to have a set or two.
    The chopped one is the ongoing project,
    the gray one is an original issue
    with polished styrene .
  22. melsfine39
    melsfine39
    Got The WILLYS? Mel :D
  23. rat nasty
    rat nasty
    ttt
  24. nochop
    nochop
    from norcal
    Where did or how did you build an Olds Motor? I'm building a 32 five window and would like to put a olds in it,Cheers Nochop
  25. halfasskustoms
    halfasskustoms
    from Durham NC
    Its that time again. Post them up if you got um.
  26. Fortyfordguy
    Fortyfordguy
  27. Tcab
    Tcab
    Is Sunday models going tobe a weekly continueation so we can continue the rhread? It would be kool?
  28. If this thread gets bumped every Sunday, it will stay here as long as the mods will allow it.
    Subscribe to it, and you will always be able to find it.
  29. 302aod
    302aod
    from Pelham,Tn.
    I found it, but had to look thru last weeks models get to the new ones.
  30. Pete L.
    Pete L.
    from New Jersey
    The ragtop is really cool...the original issue by Monogram was molded in an actual 1936 Ford color. I have several glue bombs I'm trying to redo.
    Your club has a really nice website, links to lots of great builds !!!
