Technical Flathead Fan bearing
Discussion in 'The Hokey Ass Message Board' started by 8-Track, Mar 21, 2014.
  1. 8-Track
    8-Track
    Does anyone know where I can get a new bearing for a 1949 ford flathead truck wide belt fan. it looks similar to a water pump bearing and shaft ***embly. like the one pictured?
  2. tubman
    tubman
    I asked the same question on the flathead site, which produced this thread :
    http://www.flatheadsrus.com/viewtopic.php?f=6&t=3975&p=25427
    Unfortunately, I couldn't find either of the bearing numbers online. I am if Florida for the winter, and decided to wait until I got back to Minnesota this spring before I started seriously chasing things down. Ross really seems to have done his homework on this.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    60-64 Corvair fan/blower bearing should do the job. At least that was what I used for that job back in the 60s. As I recall the Bower/BCA part # was 900590 . But anyway Clark's Corvair parts has them $25 or so last tme I bought one.
  4. stillrunners
    stillrunners
    from dallas
    thanks....good info...
  5. ginuine555
    ginuine555
    from louisiana
    Try Chris at Shoebox Central May have what you need 405 259-9222
  6. 8-Track
    8-Track
    I came up with NSK 885586 WATER PUMP BEARING on Ebay for $31.00 it is a universal bearing than needs to have the shaft trimmed to fit
  7. tubman
    tubman
    8-Track,
    Thanks for finding this source. The only place I found them wanted a minimum order of 50 (they were a lot cheaper, though). If you would, can you post how it all worked out when you are finished?
    Tubman
  8. Pinewood
    Pinewood
    Hey Steve, are we going to see your coupe on the road this summer?!
  9. 8-Track
    8-Track
    I hope so.
