40 ford 2-door
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by cajundixie, Mar 24, 2014.
  1. cajundixie
    cajundixie
    Hey folks , I'm new to the site, hope I can contribute, and also learn something. does any one know what would be the best and easiest rear ene to put under a 40 ford 2-door. running a S-10 ****** behinf a warmed flattie.. live driveshaft, stock rear, with the original buggy spring... thanks
  2. go-twichy
    go-twichy
    welcome from cali. i have a 40 coupe and have an ford 8" posi from a maverick that my tape messure tells me will work with the 8-1/2" ET's i plan on using. your wheels need to be part of the equation to get it right.
  3. cajundixie
    cajundixie
    Thanks Twitchy, what leaf springs are you using and what did the rear end measure length wise ???
  4. biggeorge
    biggeorge
    welcome from merrimac ma
  5. go-twichy
    go-twichy
    the springs came with the ch***is i had built for me, but the builder uses TCI stuff. the rear end is apart right now. you can find the info bt looking up ford rear ends for a early 70's maverick.
  6. hotrodharry2
    hotrodharry2
    from Michigan
    Welcome from Northern Michigan! I have a '40 Ford 2 dr sedan. It also has a Maverick rear end. I don't know what year. Used Ch***is engineering springs and kit to install. Runs down the road great!
  7. cajundixie
    cajundixie
    hotrodharry2, did you have to modify the rear end in any way , and do you know the width ??/ and thanks ... Cajun Dixie
  8. Model T1
    Model T1
    Welcome to the group. Under my 1939 Ford is a 1957 Chevy rear with 57 leaves.
    Under my 1941 Ford is an 80's Camaro with Camaro leaves.
  9. Texaswino
    Texaswino
    My 37 has a 58 inch flange to flange 8.8 Ford. The re was modified to fit.
