Alternative uses for engine parts?
Discussion in 'The Hokey Ass Message Board' started by rustysconny, Nov 16, 2005.
  1. rustysconny
    rustysconny
    Anybody have creative uses for old engine parts they have sitting around their garage? For example, my old neighbor used an inline 6 crank for his mailbox pole.
  2. Nailhead parts make good trotline weights.
  3. Aaron51chevy
    Aaron51chevy
    Pistons make good paper weights. I saw a shelf made from a flexplate cut in half then welded back together at a 90 deg. angle. I want to make a chair with cams as legs. Old intakes and carbs make excellent centerpieces in coffee tables (did it in college). Pistons are good paper weights. Valve covers as flourescent light fixtures.
  4. 53sled
    53sled
    from KCMO
    here is my favorite[​IMG][size=-1][/size]
  5. jalopy43
    jalopy43
    Cool table! My Pops used to make us kids pencil holders from old distributor caps.
  6. Slag Kustom
    Slag Kustom
    old flywheels rotors and drums make great bases for stands. conecting rods make good colum drops, exhaust hangers, headlight taillight mounts. cams make good spreader bars. flat top pistons as brake and clutch pedals. junk block cleaned up as a wine bottle holder.
  7. Smokin Joe
    Smokin Joe
    Saw that coffee table before but never noticed the wine bottles in the holes.
    Now THAT's convience and style.
    A model A wheel and tire make a pretty good gl*** coffee table top holder. The gl*** won't move sitting on the tire.
  8. It may not be exactly what you meant but I seem to remember a few years back Killer made some *****in' motor mounts from....er..well.....parts.
  9. flatheadpete
    flatheadpete
    from Burton, MI
    I made friction shocks out of Flathead connecting rods.
  10. da9tegra
    da9tegra
    from Iowa
    for our AutoTech. club at school we have car shows once a month in the summers and we use old car parts to make our best of show trophies. heres a pic of one i made for our sept. show(our last one this year) the top part rotates
    before to long i will be tearing apart an old junk turbocharger from an international and making a clock out of it
      44.9 KB
  11. InjectorTim
    InjectorTim
    Camshaft spreader bars are neat.
  12. the guy on here who puts on that ****py show Billetproof, well where ever he gets his trophies from, they are always cool (if anyone has some pictures they are well worth posting), i mean they **** too, just like his show. :D
    old conrods make good healight mounts, shock towers or steering column drops.
    a 16" length of a model t taper leaf front spring makes a damn good wedge, prybar, etc.
    old nailhead motors make good boat anchors.
  13. burndup
    burndup
    from Norco, CA
    a few shot lifters (and/or wrist pins) become invaluable if you leave them by your shop press.
    Killer also gets credit for con-rod headlight stands!
    Con rods also make good disposable lifting hooks.... I'd weld 'em up first.
    Valve covers are good for making tool trays... specifically on welding carts and such.
    Oil-pan BBQ!!!! Clean thoroughly...
    Alternators /generators that still work can be strapped onto other things that spin and still generate electricity... eg lawnmower engine, etc.
    AC pump- air compressor.
    lawn mower/motor scooter piston and conrod = *****in shiftknob
    valve springs /MC clutch springs.... 1000's of uses.
    Nuts and bolts... life savers!
  14. KIRK!
    KIRK!
    Billetproof trophies for the last nine years.
  15. Bugman
    Bugman
    Cams also make great towel racks.
  16. trey
    trey
    Damn, maybe I get can get credit for connecting rod motor mounts??
    trey
  17. Smokin Joe
    Smokin Joe
    I used to have a benchtop carb holder made from 4 valves and a steel plate. Just cut out a big hole so the ****erflies can open and add threaded holes for studs to mount the carb. One of my Impalas in high school had a Chevy piston and rod sticking out of the homemade console after I welded it to the cut off Compe***ion Plus shifter handle. Headlight switch and Cig. lighter in that same console were valves. Sold the car before I figured out how to use more valves as radio knobs. I'm sure most of us have made a grinder base out of an old wheel and a chunk of pipe to alow the grinder to dance around when you try to use it. I've also seen piston rods used as tailpipe hangers and bumper brackets.
  18. Rhino
    Rhino
    from ST. Louis
    I have a caliper out of a concrete truck I use for a King Kong ash tray. A buddy of mine has a mag wheel cut in half and uses it for a garden hose hanger on the side of his house.
  19. flatheadpete
    flatheadpete
    from Burton, MI
    I use a 17 inch polished Torque-Thrust for a hose reel.
  20. demonspeed
    demonspeed
    Pistons can be flipped over and used as ashtrays (just clean em up before you do it though), Old steel rims can be used as bases for stands, and I've seen front drop axles used as spreader bars and chopper downtubes. I read in a magazine once that pistons can also be used as motor mounts but I haven't quite figured out how yet, but if anyone knows, its probably a HAMBer
  21. Slonaker
    Slonaker
    I have some jack stands made out of old Ford rearend parts that i bought at an estate sale. I don't thing anybody else knew what they were for. I don't really trust them to hold up my car, but I have been trying to come up with a good use for them. I'm just learning to weld, so I am trying to think of a project that I can use them in. For the moment, they just sit in the garage looking like rusty traffic cones.
    I'm still trying to come up with a car parts mailbox post that han't been done before. No luck with any new ideas so far.
    I considered using one of the jack stands, but I don't thing anyone would know what it was by the time I extended it to the right length. Maybe I can extend the length with a cam or something. :)
    Slonaker
  22. cornfieldrodder
    cornfieldrodder
    An old 36 Ford front axle with welded spindles from an old trailer made a cool grinder stand that I built for an artist a few years ago.
  23. JrDragsterPunk
    JrDragsterPunk
    a few days ago i used some old chain link from my dragster as a bracelet type thing around my wrist. it takes awhile to get on a off though.:D
  24. Chopp47
    Chopp47
    Take 1 ***mins cam and gear some 1/4 plate a cheap vise, Presto you have a third hand
  25. built and anvil stand out of some 6" Schedule 80 black iron pipe and a model T flywheel
  26. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    I use a flathead Ford three speed cluster gear for a door stop.
  27. cornfieldrodder
    cornfieldrodder
    I'm planning a garden tractor trans for a gear reduction to use my 50s Craftsman bandsaw for wood and metal.
  28. rustysconny
    rustysconny
    Thanks for all the great ideas. Now if I could just get the Mrs. to agree to some of them. She's been nagging me to get a new coffee table . . .
    I was bored at work and thought up a couple more:
    A ceiling fan using an old water pump fan
    Connecting rods for seat recliner handles
  29. Winfab
    Winfab
    I used a C.I. Powerglide bellhousing for my bench grinder stand base.
  30. polisher
    polisher
    Alliance Vendor
    Use an old fly wheel to steady your mailbox post.
    I use valves and push rods for tapping dinks out of trim.
    I prefer the ones out of big diesels as radius's are bigger, but sometimes I like a thinner one.
    Valve edges are good for repairing creases and folds in trim edges.
