Best way to lower a 64 ford f100...
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Brandenp, Sep 19, 2012.
  1. Brandenp
    Brandenp
    from Gautier MS
    i just bought a 1964 ford f100 straight 6,goal is i just wanna make it into simple hot rodding truck,flat black white walls with moon caps.
    wanna lower it right off the bat but not sure the best way to do it.
    this will be the first time lowering a vehicle.
    anything will help
    thanks!
  2. DRUGASM
    DRUGASM
    Drop axle and mono leafs up front. Get ahold of username Used Up Junk and see how low his is. Ride will suffer a little bit it'll look cool.
    Welcome to the HAMB.
  3. Brandenp
    Brandenp
    from Gautier MS
    thanks man! just look at his truck and thats pretty much how i want it.
    i appreciate it!
  4. Ben Jamin
    Ben Jamin
    Hey, have you lowered the truck yet?
  5. lrs30
    lrs30
    from Kentucky
    Lots of good info over at fordtruk.com. Everybody has different opinions on "the best way" do some research, check your budget, and ask yourself about your mechanical abilities. Plus you need to ask your what are your intentions with the truck.. Lots of things fall into play. Once your able to answer some of those questions, then post them up here and you will get a lot of help. But to be asking the best way, that probably won't get lots of feed back.
    You can lower it with something as easy as removing a few individual leaves ( or is it leaf's lol) from each spring pack, you can do axle flips, drop axle, you can do front clips from other cars, like Volare, crown Vic's, or jaguar, you can do the whole mustang II route.. Lots of options to choose from.. I know I didn't give you an exact answer but you really didn't state your intentions with the truck.. Hope this helps and not confuses you.
