Hot Rods 285/70x15 vs 265/75x15
Discussion in 'The Hokey Ass Message Board' started by cabriolethiboy, Apr 2, 2014.
  1. cabriolethiboy
    cabriolethiboy
    I have finally worn out my BFG 285/70x15's on my hiboy. I am thinking about changing to 265/75x15 instead because;
    1. they are cheaper
    2. I want a slightly skinnier tire to look less cartoonish
    Has anyone used these on the back of their car? A lot of the ones I have looked at have a pretty aggressive tread. I don't want it to look like I have snow tires on the back. Or should I just bite the bullet and buy the BFG 285/70x15's?
  2. lothiandon1940
    lothiandon1940
    Are the 265/75x15s that you are looking at BFGs as well?
  3. cabriolethiboy
    cabriolethiboy
    Mainly, the BFG LongTrail T/A Tour, but I have looked at others. Just online, I have not seen any in person.
  4. cabriolethiboy
    cabriolethiboy
    another one is the Firestone Destination LE. I have 145x15's Firestones on the front so these might match;
  5. Jalopy Joker
    Jalopy Joker
    what wheels and ride are you putting them on? pic of 285/70/15 on 10" rim
  6. I've used the BFG Trail Tours in the 265-70 and 75 versions in place of the 285's with good results on 7 and 8 inch wheels. On my track roadster I ran pressures around 18 to 20 pounds with no problems.
    Charlie
  7. cabriolethiboy
    cabriolethiboy
    American TQ's 15x10's on this;
  8. cabriolethiboy
    cabriolethiboy
    Charlie, got any pics?
  9. lothiandon1940
    lothiandon1940
    I think Charlie has the right idea with 265s on a 7 or 8 inch wheel. Not sure they would look right on your 10 inch wheel. Would be a shame to have to buy yet another pair of wheels just for the desired change. By the way, nice cabriolet.
  10. cabriolethiboy
    cabriolethiboy
    You might be right about the wheel width. Specs say 7 to 9 inch wheel. I was hoping someone would already have some mounted up so I could see what they looked like.
  11. AnimalAin
    AnimalAin
    I switched some time ago (after BFG quit making them, and before they were available from specialty vendors). If you don't know exactly what you are looking for, it's unlikely you will be able to tell the difference. I run them on eight inch wheels.
  12. john mullen
    john mullen
    hear are 265/75/15s on 8 inch wheels on rear 225/75/15s on front
  13. lothiandon1940
    lothiandon1940
    Very nice truck, John. I think those 265s look just right on an 8" wheel.
  14. john mullen
    john mullen
    lothiandon1940!...Thanks
    I had OG 16" wide whites before I changed to the radials. At first I thought they were to much but after I got use to it I think they are just rite.. It drives really well now...
  15. 327Eric
    327Eric
    The 265s fit and looked real good on my 8.5 slot mags. I wouldn't run them on anything wider though.
  16. 47.Poncho
    47.Poncho
    Here's my coupe with 265's. Uniroyal. Love the 265's. 235's are nice but still not tall enough in my mind, pending on the car.
      317.3 KB
  17. philly the greek
    philly the greek
    from so . cal.
    265/75/15 on my roadster
  18. philly the greek
    philly the greek
    from so . cal.
    285'70/15 on 10" wheels
  19. Dale Fairfax
    Dale Fairfax
    Steve: have you checked with Riley Park Tire in Greenfield for style/selection and price?
  20. cabriolethiboy
    cabriolethiboy
    What width wheels do you have with the 265/75x15's?
    Also what brand of tires do you have?
  21. philly the greek
    philly the greek
    from so . cal.
    The tires are BFG and the wheels are 8" wide .
  22. tjet
    tjet
    Looks good. I was going to order that same size BFG's for my pickup, but I found some serviceable L-60's for the rear. For wheel size, I have 15x8.5 in the rear, & 15x6 in the ft.
    Going to order a new pair of Pro-Tracs for the front (235-60-15)
