Projects Beware the Amateur with a Sledgehammer
Discussion in 'The Hokey Ass Message Board' started by Johnny49, Apr 5, 2014.
  1. Johnny49
    Johnny49
    Well, separating the hubs from the front drums today was a lot easier than I thought it was going to be. Unfortunately, it was also a lot easier to ruin the hub with the small sledgehammer I was using to drive the studs out, as you can see with the hub in the foreground. Don't know what the heck I was thinking. Didn't even notice it until afterwards. Maybe the wife is right when she calls me "Bam-Bam."
    In addition to that little example of amateur genius, you'll notice that the studs are still sticking through the backing ring on the left. That's because they had been welded to the ring. No idea why. I was also reminded what happened when I originally tried to have all the drums turned. Not enough material left to turn on the right front, and one of the rears was warped (according to the shop guy). Which is why I figured all four should be replaced. And because I wasn't being careful with the sledgehammer, now I need the hubs too. I know we'll be able to find them somewhere, just a matter of making it fit within the budget...
  2. oldrelics
    oldrelics
    from Calgary
    I've learned too:
    Hammer "variable swinging press", used when a "hydraulic press" is called for= damage.
  3. Same **** happens when the studs are swedged and hold the drums to the hubs. A special cut off tool that removes the swegded area can save a lot of grief.
