Technical what std. trans behind a FR Ford. 390
Discussion in 'The Hokey Ass Message Board' started by rockin rebel, Apr 5, 2014.
  1. rockin rebel
    rockin rebel
    hello. I am thinking about putting a std trans, 5 speed in my 54 Mercury car. one guy says Mustang 5 speed is not strong enough :confused: any thoughts.?? thanks...
    ***tle should read, FE don't know why we can't change the ***tle ?
  2. fiftiescat
    fiftiescat
    from NY
    I have a '54 as well... I was told by several ****** shops that even a T5 behind my y block would not hold up. A few buddies have blown T5's in similar shoeboxes... I went with a 1 3/8" big block 4 speed toploader. If you have to have a 5 speed, I'd go with a TKO
  3. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Many guys have bought the mustang 4 cylinder 5 speed by mistake and those won't hold up long in a V-8 application..For cruising/road trips, the 5.0 5 speed would hold up, however if you're going to flog it, I agree the TKO is much stronger, would live under the abuse and would be the better choice. Also, Liberty will build a 5 speed to you needs at a reasonable price..
  4. GTOMUSTANG
    GTOMUSTANG
    from ct
    Looking in the Tremec catalog, brand new T-5's are rated for 300 ft lbs of torque. Used, maybe less, especially since Foxbody Mustang shifters hung up on the 3rd gear shift, so the synchros typically get bruised up. The new TKO's handle 500-600ft lbs. what's your FE putting out?
    needless to say, curb weight and your desire to downshift in place of using the brakes, changes the amount of abuse the trans will be seeing. The only things that are cheap, are the things you do only once.
  5. rockin rebel
    rockin rebel
    thanks guys. what is a TKO.? I only have built Chevies.. also I am 65 and will not be betting it up, much..lol
  6. rockin rebel
    rockin rebel
    also what bellhousing would I use..seems Ford has many different ones..thanks again...this is going to be a custom, so mostly just want a stick shift, for shifting..
  7. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
  8. It's a Tremec 5 speed on steroids.
