Technical carb blasting/cleaning
Discussion in 'The Hokey Ass Message Board' started by trbomax, Apr 6, 2014.
  1. trbomax
    trbomax
    Specifcally, AFB aluminum carb castings. I used to plastic media blast snowmobile clutches and they came out looking like new.This is an old, matched set of dual quad carbs that I cant take a chance on messing up.They are really not bad but I want them looking new.Has anyone tried plastic media on carb castings? they are not dirty or badly corroded,I just want that fresh out of the box look!
  2. Seepwater
    Seepwater
    Try soda blasting...do a web search you can build a soda blaster for almost nothing!
  3. vtwhead
    vtwhead
    gl*** will fill all the small holes....not good. Try soda as it disolves
  4. I use sugar sand
  5. ididntdoit1960
    ididntdoit1960
    from Western MA
    Whatever you choose - try it on a "core" carburetor first (anything cheap at the swaps) your definition of "factory" and someone elses may be totally different - found this out the hard way with an intake...
  6. There are a couple of threads on this already- soda blasting is the answer.
  7. trbomax
    trbomax
    looks like soda it is. thanks!
