Wheels
Discussion in 'The Hokey Ass Message Board' started by MrManz, Nov 16, 2005.
  1. Does anyone know where i might find some steel wheels that are a 5 on 4 1.4? The rear end is out of a 91 ford thunderbird.
    -Andrew
  2. Thirdyfivepickup
    Thirdyfivepickup
    What size wheels? I know there were T-birds that came from the factory with hubcaps... you might check there. I think 88-97 is pretty much the same car.
    That is also an early Mopar bolt circle.
  3. moparmike
    moparmike
    from Austin, Tx
    Look around for 60's A-body Mopars. They are gonna be 13's or 14's, though.
  4. BostonCat
    BostonCat
    89+ T Birds and Cougars, Windstars, as well as Sables and Taurus...es.
    All of these would be FWD offset wheels though.
    Check out www.TCCOA.com articles section for info on changing over those hubs to a 5 x 4.5 bolt circle. Not that bad if it's a disc brake rear end.
  5. 53sled
    53sled
    from KCMO
  6. 5 X 4"MakeModelYears of Production
    DodgeDart, Demon, ******* (w/o disc brakes)1963-72
    PlymouthBarracuda, Cuda, Duster, Valiant 1963-72
    PlymouthScamp, Duster, Valiant (w/o discbrakes)1971-75
    5 X 4 1/4"
    Volvo140, 164
    VolvoAllThru 1989
    FordT-Bird1989
    I see a Volvo s****yard in your future...
  7. am i going to be hosed on trying to find two 15in steelies for the rear of my bucket? i dont really care what the offset is. I just need it to be a 15in wheel with that pattern. I dont want to change out the rear axle and i dont want to spend 115$ on two wheel adaptors. so do you think that the best place would be like a slavage yard or pick and pull?
    -Andrew
    And thank you all for the help
  8. 53sled
    53sled
    from KCMO
    Volvo s**** yard in pittsburg kansas, maybe try them? surely there is a gorilla who could look into that.
  9. BostonCat
    BostonCat
    If all you want are 15 inch steelies, regardless of offset, width or look, hit the junkyard for a pair of wheels off a Taurus. There are at least 137 of these cars in any given yard.
    Should be 15 x 6 and in the correct bolt pattern.
  10. muffman58
    muffman58
    I`m pretty sure that you mean 5x4-1/2 pattern right? I have three of those rear ends and there ALL 5 on 4-1/2! Yes, Ranger steelies will bolt right on! You don`t want Taurus wheels because of the offset.
  11. i was told that 5 on 4 1/4 was the bolt pattern for a 91 thunderbird. Thats what im looking for. SO a ford ranger will or will not fit?
    -Andrew
  12. BostonCat
    BostonCat
  13. Orange Crate
    Orange Crate
    If your T-bird rear is an independent, I think you'll find it's a metric pattern. Best bet is to have drums and axles redrilled to 5 on 4 1/2.
  14. Philofab
    Philofab
    Independent T-bird rears are 5x 4.25 not a metric pattern.
  15. steevil
    steevil
    "small" dodge, Jeep,Bronco2/Ranger/Explorer/Aerostar/ SN-95 Mustang are all 5 x 4½" bolt pattern. They will NOT FIT.
    4 1/4 in.
    1992-90 DODGE - Monaco
    1992-88 EAGLE - Premier LINCOLN - Continental
    1999-86½ FORD -Taurus
    1997-89 Thunderbird,
    1996-95 Windstar
    1992-86½ Taurus
    1992-89 MERCURY - Cougar
    1992-86½ Sable
    1996-90 PLYMOUTH - Laser (some 4 1/2")
    The metric size is very close...
    108 mm.
    1999-94 VOLVO - 850 Series, S70/V70 Series
    1999-90 940/960 Series
    1994-82 740/760/780 Series
    1994-79 240 DL, GL, GTL
  16. I think I have some early "artilery" style wheels in that bolt pattern. Larger dia. than 15" though.
    Dan
  17. ElPlymino
    ElPlymino
    from Orcutt
