1931 Chevrolet pics and tech info wanted.
Discussion in 'The Hokey Ass Message Board' started by Kustchops, May 24, 2010.
  1. Kustchops
    Kustchops
    I got a 1931 Chevrolet two door sedan, it was an old hot rod. I am redoing a lot of the cobble. I am looking for some pics of old school builds, all I find is high end stuff, any one in their picture collections have full fendered low slung rods. Also I am using a six inch dropped axle with two inch dearched springs., I would like to lower it another couple of inches, any thoughts the springs kinda stop it from going any lower. C Notch?
  2. ken1939
    ken1939
    You using a Ford Axle or the GM axle with dual leafs?
    You have alot of drop already if that is for the front end.
  3. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Kerry swapped the axle over the leafs for a couple inches but since you have a 6" drop axle I fear your scrub line will interfere.
    Could try putting a Hemi in there. the extra coupe hundred pounds might lower it a bit haha!
  4. Kustchops
    Kustchops
    Its got a speedway dropped tube, 54 chev spindles and brakes, two inch dearched springs all rebuilt. I am just used to model A's they can go a bit lower. I wanted it to sit like my last car.
  5. wingman9
    wingman9
    from left coast
    It's tough to get a '31-'32 Chevy real low in the front because of the arch of the fender. You have to lave a little room (about 2-3 inches from the crown) for suspension travel.
  6. Kustchops
    Kustchops
    The red one is low, I wonder how its so low with stock springs up front? I like the stance.
  7. 34toddster
    34toddster
    from Missouri
    Looks like a 4 bar and a dropped Ford beam
  8. cruzincougar
    cruzincougar
    I tried to get my 31 Chevy roadster low for a year trying all kinds of combinations with the semi elliptic springs. I even tried a 7" dropped axle.
    I've gone to a 6" with a reversed eye spring over the axle, still not as low as I want and unless I go to 17" rims, scrub line is a joke
    If you're going to run with fenders, I would think the only way to get it down is IFS. I'm not running fenders and an IFS, for the most part, looks funky on a fenderless car
  9. scaryfast
    scaryfast
  10. everclr190
    everclr190
    I would like to put disc brakes on my 31 chev sedan. Using the original straight axle anyone know which spindle fits this application!
  11. nailheadstl
    nailheadstl
    Master power brakes makes a setup for the stock spindle
  12. Hyway Hauler
    Hyway Hauler
    ECI Brakes also sells a Disc Conversion kit for about 280$. I used it on my '31 Chevy. The '31 in my Avatar has a 3" Dropped Axle from Sid.
