Technical stromberg 97 leather gasket
Discussion in 'Traditional Hot Rods' started by jan bogert, Apr 9, 2014.
  1. jan bogert
    jan bogert
    my needle and seat was sticking , and I took apart the top end of the carb. can I flip the leather gasket up ward to install it?
  2. F-6Garagerat
    F-6Garagerat
    You took seperated the cast iron base and the main body apart? The gasket with the 2 big holes and 3 screw holes? If it's in good shape I have done it in the past. I don't flip them over though. Just put it back on.
  3. 42merc
    42merc
    If you are talking about the leather accelerator pump cup-- NO don't fold it upward, install with edges down, being careful not to catch the edge on the pump well.
  4. Ole don
    Ole don
    Put a few drops of clean motor oil on the leather and work in in for a few minutes with your fingers.
  5. jan bogert
    jan bogert
    thanks guys,, the float sank, had a fine crack in it. U MAX is sending me a new one with the new horn gasket.
  6. Mr48chev
    That would cause flooding for sure. You still have me on "flipping the leather gasket" as the only leather I know of in the carb is on the accelerator pump as 42 Merc and OL Don mentioned in posts 3&4.
  7. jan bogert
    jan bogert
    48,, I worked the leather seal from the acc. pump in with my fingers and a fiber tool. thanks guys
  8. Mr48chev
    Good enough. Around this board you can't always get away with ***uming that a guy trying to do something on his old car knows what he is doing.
