Technical styleline flasher prob
Discussion in 'The Hokey Ass Message Board' started by motleycrue, Apr 10, 2014.
  1. motleycrue
    motleycrue
    hey guys, i converted my 49 to 12v, got rid of numberplate lights, an fitted caddy rears where numberplate lights was,wiring them into original rears, they flash too fast, ideas plz?
  2. stimpy
    stimpy
    need a flasher can that can handle more lights . more lights more amp draw .
  3. motleycrue
    motleycrue
    its got 1 thats 40/46 wts
  4. ROADSTER1927
    ROADSTER1927
    Use a flasher for 4 way flashers, they will handle the load.
  5. motleycrue
    motleycrue
    can you explain that plz? i dont understand,do you mean for hazards?
  6. stimpy
    stimpy
    whats the part number on the back of the can ?
    try a number 570 flasher can
  7. coryw
    coryw
    from Omaha, NE
    On most cars when a light burns out the flash rate increases (less load). I'm surprised that yours is going faster with increased load. Electronic flashers are supposed to be non-load dependent but I don't know how much load they can handle. Might be worth looking into.
  8. motleycrue
    motleycrue
    exactly, thats what i cant work out , i even tried adding an extra light inside trunk to see if it made diffrence, none
  9. stimpy
    stimpy
    on the semis up to 20 on some of the Grotes , my DD pick up I use a Grote 44540 electric/mechanical ( 570) and it flashes all 10 lights on the truck and trailer with no problems . and when I unhook the trailer the speed stays the same so no changing it out .
  10. squirrel
    If it had one back light on each side before, and has two on each side now and flashes faster, then it probably has a thermal flasher. They work by getting hot, the heat makes the bimetallic strip "pop" off. If the load increases, they heat faster, so it will flash faster.
    Try a different flasher can.
  11. motleycrue
    motleycrue
    shes sorted now guys, i fitted a flasher that was twice the watts, thanx for your help,
