Technical Vinyl on door panels how to add "bagginess"
Discussion in 'The Hokey Ass Message Board' started by musthave, Apr 15, 2014.
  1. musthave
    musthave
    from in a house
    How can I make this "bagginess" that is shown on this door panel?
    The top left/center section, it bunches together a bit. How is this done?
  2. wbrw32
    wbrw32
    It is done with elastic sewn along the top and bottom..
  3. mustangsix
    mustangsix
    Everything I sew ends up looking wrinkly and baggy like that.....
  4. hahhaah, me too ! I dont need the elastic sewn in for effect
  5. musthave
    musthave
    from in a house
    Wow, I had no idea that was how it's done. I will have to get some elastic and try that! Thanks for the advice.
  6. Dreddybear
    Dreddybear
    It's called Ruching. Careful with it, it can make things look like an early 90's BMW or a late 80's prom dress...
  7. speedyb
    speedyb
    from socal
    Hahaha
  8. Airhart
    Airhart
    That's how I do it. Just go at it thinking "Man, I really want this smooth and neat" and it will end up just like you want! :D
  9. Hackerbilt
    Hackerbilt
    Ha...amateurs!
    I do that with steel when I weld in a patch! :D
  10. 54fierro
    54fierro
    from san diego
    coffin pleats like the lowriders?
    I would pinch/fold the material while you were sewing it or gluing it down. It would give you that effect
  11. dadseh
    dadseh
    Looks like ****!
    To each his own.
  12. Zerk
    Zerk
    I'm having trouble believing that it's intentional. Looks almost like the backer board cracked and let the material bunch up.
  13. ago
    ago
    from pgh. pa.
    Good one hacker LOL
    Ago
  14. musthave
    musthave
    from in a house
    It's original, they all have it, same spot, almost the same look. Going to try to do it myself this weekend.
  15. john worden
    john worden
    from iowa
    This is it. Gather the fabric as you fasten it down.
  16. indyjps
    indyjps
    I wouldn't replicate it, if you do maybe add 2 even wrinkles, the panel shown looks very bad. Fold the material over to make a pleat, if its fabric you can low heat/iron the pleat in to help keep it straight while sewing, use straight pins to keep the pleat in place while sewing. If you've ever seen a curtain sewn its the same operation, just a smaller pleat.
  17. Phucker
    Phucker
    from Kansas
    You registered just to ask how to make door panels look like ****?
  18. 33sporttruck
    33sporttruck
    I agree with Phucker !!! I did Custom Upholstery for several years. My Customers would have "Kicked My *** !!!" over work like that.................... Jeff
  19. Muttley
    Muttley
    This guy thinks it looks sweet and would like to know how much you would charge to upholster his LeBaron convertible.
  20. I think it would look better if that whole inserted panel was all done rather than a couple of pleats because it does look a bit like an eff-up. Hey, have a crack at it. Show us how it comes out. Something a bit different, a bit European, aka early 2000 model Mercs
