Technical Buick 12 Inch Brake NAPA Part Numbers 45 Fin Aluminum
Discussion in 'Traditional Hot Rods' started by hotrodarchaeologist, Mar 23, 2014.
  1. hotrodarchaeologist
    hotrodarchaeologist
    from Maine
    Hello.
    After installing a few sets of the 45 fin Buick aluminum brake drums on my Hot Rods with the Buick backing plates, I thought I would post these numbers I have gathered in case they may help someone out.
    These are part numbers if you are using the original Buick backing plates with the drums.
    These are all NAPA numbers;
    Front shoes TS-197 (12" by 2 1/4") (I also use these on the back)
    Front shoes TS-127 (12" by 2 1/2") (These do not always work, some have different depths where the pins from the cylinder meet the brake shoe)
    Front wheel cylinder 14493
    Front wheel cylinder 14494
    Rear wheel cylinder 13388 RT
    Rear wheel cylinder 13387 LT
    Adjusting screw 80562
    Adjusting screw spring 80503
    Shoe link 80743
    Spring for rear parking brake cross piece 80744
    Maxi pack (springs, pins, cups, misc.) 2225
    The maxi pack will give you an ***ortment of pieces. NAPA tells me that they are not selling some of these pieces separately anymore.
    When getting wheel cylinders, look them over as the do not always match right to left in style / shape. I usually have them pull down two or three of each and cherry pick a matched set.
    I use the red return springs from the 2225 maxi pack.
    Pins should be #1's.
    I am always willing to answer any questions if I can, just send a PM. I have installed these 45 fin Buick brake drums with the Buick backing plates on early Ford round back spindles and small bearing 9" Ford rears.
    Got this info from FRAMES:
    I have been using advance #w13387 and w13388. 1 1/8" 70 ford 1/2 ton. $9.99.
    kidcampbell71 and Max Gearhead like this.
  2. Good stuff man !
    Thanks
  3. Brizo
    Brizo
    from Indy
    Are the Buick finned aluminum drums being reproduced yet?
  4. Blind Elwood
    Blind Elwood
  5. stillrunners
    stillrunners
    from dallas
    thanks for the info and research....
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
    x 2
  7. ago
    ago
    from pgh. pa.
    Hey Hotroda,
    Good info, I fabed Buick brakes on the rear also with 9" bearing ends on my Quick change.
    The front brake cylinders for the Buick drums, I got a new set off 66 and newer. They have 1/16" bigger bore, pedal effort a little less with the bigger cylinders. I only buy brand new brake parts and cylinders. too many problems with rebuilt.
    Ago
  8. brady1929
    brady1929
    Cool. Thanks.
  9. Rusty
    Rusty
    Good stuff thanks for sharing
  10. freiertpc
    freiertpc
    Hey I want to put a set On my 53' belair kustom can i just slip all the buick gear onto my gm spindles?
  11. Flat Ernie
    Flat Ernie
    Tech Editor
  12. 3wLarry
    3wLarry
    from Owasso, Ok
    I got a nice pair of 45 fin drums that are ready to go, if anyone needs them
    kidcampbell71 likes this.
  13. raven
    raven
    How are you mounting the backing plates to the Ford spindles?
    r
  14. Flat Ernie
    Flat Ernie
    Tech Editor
  15. hotrodarchaeologist
    hotrodarchaeologist
    from Maine
    I ran into some difficulty with shoes on my most recent (this weekend) 45 fin front set up...sometimes the 2 1/2" shoes will not work. I used the 2 1/4" shoes, they work well. I updated my info above...
