Technical SW Mech Oil Pressure Gauge
Discussion in 'Traditional Hot Rods' started by 2935ford, Apr 17, 2014.
  1. 2935ford
    2935ford
    Anyone using a SW mechanical oil pressure gauge in their 265 Chev engine?
    My sender is set up for the idiot light.....I want to convert it to a gauge. I have an old SW mech gauge I would like to use but it is minus the tubing and fittings but I think they are still available.
  2. tommy
    tommy
    I'm a big fan of SW mechanical gauges. Most any parts store will have the hookup tubing and fittings in a kit. I don't currently have a 265 engine anymore but the size and manufacturer of an engine wont make any difference. I personally don't care for the plastic lines but the copper tubing has always been easy for me to find.
  3. 2935ford
    2935ford
    Thanks tommy....I'll visit my local parts store. I am also using the SW mech temp gauge. I picked them up years ago and now have the opportunity to use them. I was a little concerned about having liquid inside a tubing inside the cabin but they have used them very successfully for eons, right?
  4. ago
    ago
    from pgh. pa.
    Liquid inside is no problem, most of the older cars had copper oil pressure lines.
    Ago
  5. Tudorp
    Tudorp
    I just picked up a tubing kit which included fittings on ebay for about $8 if you cant find one locally, give evilbay a try.
  6. alchemy
    alchemy
    Don't buy the plastic tubing kits. Many guys have experienced the surprise of hot oil squirting their leg after the plastic rubs on something sharp for too long.
    The copper tube kits don't cost much more, and will last a lot longer. It's smart to make a small coil (like a spring) at the engine end before you run it through the firewall. This will prevent the engine's vibrations from pulling on the line and kinking it.
  7. tommy
    tommy
    unlike the oil pressure gauge, a mechanical temp capillary, can't be repaired by a novice. I sent mine out for repair and it works just fine.
  8. Window Licker
    Window Licker
    i always go to the hardware and get 1/8 copper tube and the necessary fittings. haven't had an issue yet, plus its been much cheaper than the parts store kits
  9. 2935ford
    2935ford
    thanks all
    my temp gauge and capillary tube is in good condition.
  10. Ole don
    Ole don
    I have used the plastic tube for years with no problem on several cars. Run it like the factory would have. No place to kink, well insulated, and grommets at the firewall.
  11. Tudorp
    Tudorp
    I like the idea of copper tube, but I have used plastic tube for decades. I have to admit when I was younger, I did have an issue of chaffing a hole which ended up with oil dumping in the floorboard, but you only do that once before you learn to take precautions. I always sleeve my plastic tube with rubber va***m or fuel line to keep it from chaffing through the plastic tube, along with thoughtful routing and haven't had that issue since.
  12. tommy
    tommy
    You can't polish the plastic stuff.:D
  13. 2935ford
    2935ford
    tommy....polish will not be an issue with me! :)
  14. Mike VV
    Mike VV
    from SoCal
    Also used the plastic for many-many years on several cars without problem.
    Just be sure there is no chaffing anywhere.
    Though, on the car I'm currently working on, I'll be using steel braided teflon line.
    Mike
  15. tommy
    tommy
    It is not for me either except it is just so easy with a rag and some chrome polish between your fingers. It won't last real long but again it is just sooo easy. I'm not a "buff and shinner" either.:D
    I used the plastic stuff once back in the 60s as a temporary test of the oil pressure. It got against the exhaust manifold and sprayed the whole engine compartment with oil and chased away all the mosquito's with the smoke. It was just a test and no real protections were taken. It would probably be just fine if installed correctly but I don't like the look. JMHO
  16. 2935ford
    2935ford
    pretty sure I won't be using plastic.
