Technical 34 Coupe: Stance/rake with choice of springs
Discussion in 'Traditional Hot Rods' started by carrera600, Apr 6, 2014.
  1. carrera600
    carrera600
    Iam planning my build and have an issue with the stance / rake of my 34 coupe. Iam using the stock rear axle and dont want to change any crossmember or body sections.
    REAR:
    Posies offers a stock replacement rear spring with a drop of 2 1/2“ below stock height.
    This drop is more an than an 1934 original reversed eye spring will give me.
    The Posies spring is getting the rear as low as it gets in my opinion - spring wise!
    FRONT:
    In the front i am having a 4“ dropped original axle with a stock spring perch boss width to retain my unsplit wishbone.
    Now Posies is offering a front reverse eye spring, that is lowering the car 2“ from stock height.
    Result: The front has a total of 4“ drop from stock height and the rear has a 2 1/2“ drop from stock height.
    My question:
    1) Is that a good look or does it look stupid ?
    2) Should i rather opt for a front reverse eye spring with a drop of 1“ instead of 2“ ?
    3) Anybody riding this combination ? Any Pictures?
    Tyres: I would like to run either 16“ spoke rims with 600 tyres front and rear or 16“ steelies with tyres 600 in the front and 700 in the rear
    I suppose i could also go with 15“ rims front and back to lower the car just that little bit more.
    Any suggestions and pictures would be really helpfull.
    Thanx
    panel beater likes this.
  2. ss34coupe
    ss34coupe
    Here are a couple of pics of a chopped 34 three window that I built 20 years ago. It had a four inch dropped front axle with a reversed eye spring. There is a 57 Ford nine inch rear end using a stock 1934 rear spring. Only one leaf was taken out of the rear spring, but I did have a spring shop flatten it to get the rear down some. You can see that the coupe sat just right and the ride was surprisingly comfortable with the transverse leaf spring suspension.
  3. LBH
    LBH
    Here is my '34 ...... 4" dropped Super Bell with a Posie reverse eye in front and a Posie super glide that I had a spring shop reverse eye the main leaf and dearch it 1 inch ...........
  4. 3banjos
    3banjos
    from NZ
    Your wheel/tire combo is ***isting in that spot on stance. Looks great.
  5. ss34coupe
    ss34coupe
    I agree. Great looking coupe with a perfect stance.
  6. MAD 034
    MAD 034
    from Washington
    I may have missed it but are you running fenders?
  7. 3banjos
    3banjos
    from NZ
    Good point. I would think the 600/16 at almost 28" would look a little tall, fendered or not.
  8. LBH
    LBH
    Yesterday was the first time that I was able to successfully upload a picture .....(not very sharp) .......... so I got up this morning and decided to see if I could remember how ...........tp
  9. 3banjos
    3banjos
    from NZ
    Thats a cool pic of a ****** nice car. Interesting to see the tire combo. Best of both worlds.
  10. LBH
    LBH
    The rears are 31" tall ........which requires the wheel offset to be perfect to get them way up in the fender ........
    Jordan Mixon likes this.
  11. JasonCarGuy
    JasonCarGuy
    So what 4" dropped front axle is everyone's favorite? I'm in the same boat and getting ready to buy a front axle and spring? What are you guys running for steering box, F1?
  12. adavis
    adavis
    That is one fine car there, LBH.
  13. alpo
    alpo
    very nice Coupe LBH.
    You could go with a smaller tire size and lower profile in the front. I use 235 70R15 for the back and 185 70R14 for the front or you could even go with a 60 or lower For the front.
    I am using a Vega Steering box. That is an original and not a repo. and a Super Bell Axle.
  14. LBH
    LBH
    Thanks for all the nice compliments. I haven't posted much, just figured out how to upload pictures ........ so haven't had much to say. I considered smaller front tires, borrowed traditional sizes from friends ........ but the car has a lot rake the way it is........ plus I am really into how this car handles and stops .......... the front tires are the same width as the rears, which I like. It steered a little hard until I had Neil Jennings build a 1937 Hudson Teripane (sp?)steering box .......... which is the best there is in my opinion !!....tp
  15. J & D
    J & D
    I have the same box for my 34 LBH. If you can contact me.
  16. LBH
    LBH
    His boxes are the best! ..........
  17. turbodickie
    turbodickie
    Neil Jennings builds the best for sure, I have them in two cars.
  18. carrera600
    carrera600
    OK, here are some more pictures of cars with a "stance"
      47.5 KB
      66.4 KB
      42.2 KB
      53.7 KB
      49.6 KB
      54.1 KB
  19. carrera600
    carrera600
    Some more !
      46.3 KB
      67 KB
      72.2 KB
      56.7 KB
      44.6 KB
      55.9 KB
      43.2 KB
  20. carrera600
    carrera600
    and more!
      48.3 KB
      66.8 KB
      51.9 KB
      67.2 KB
      59.9 KB
      43 KB
      66.7 KB
  21. carrera600
    carrera600
    last ones !
      81.5 KB
      65.3 KB
      61.7 KB
      65.5 KB
  22. carrera600
    carrera600
    That looks very nice, although changing the rear axle and doing modifications to the body is what i want to avoid because of the workmanship involved and i cant think of anybody down here beeing able to do something like that.
    The rear rim looks like a 15" one !
  23. carrera600
    carrera600
    Yes, also very very nice, looks perfect !
    The front looks awesome, i want to go for the same set up.
    But to reverse a posies rear spring to get even more drop, thats daring with regards to spring travel and bump issues ! Apart from the tyre / fender clearance in the back, unless you change rear cross member and do body mods.
    I called Posies and they ***ured me that there were no issues with impairment of spring travel with regards to their rear super slide spring. It was mentioned that one could use 32 axle bumpers or cut the 34 stock ones down when lowering more. However, i heard that the spring might hit the frame before it actually reaches the axle bumpers.
    Q: Are you using stock rear axle ?
    Q: Any body modifications in the rear ?
    Q: Have you got a rumble seat in the back ?
    I have a rumble seat in the back and would worry about flingig the kids out into the field, driving over a pot hole ! NO worries about the "mother in law" though !!
  24. carrera600
    carrera600
    I heard of Vega and F100 steering boxes as replacement, but never of a Hudson Terraplane one.
    I was going to have my box rebuild by a HAMB member (needle bearings) and, in addition, use an upper steering column bearing kit. Because i have a right hand drive, there is little space due to the starter motor and the exhaust manifold beeing in the same area which causes problems with larger size boxes and adapter plates. Plus i wanted to use traditional steering, so that will not work out with that box of yours i guess.
  25. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Mine was this way when I bought it 10 years ago. Need to lower the front one of these days but its number hasn't come up yet. The steering box is a 67 cougar. I guess it is ok. A bit hard when you are not moving.
  26. ss34coupe
    ss34coupe
    You have a good eye, my friend! The rear rims are 15 by 7 and the fronts 15 by 5.
  27. carrera600
    carrera600
    I have looked at your car more than i have looked at my wife and that for a considerable time:eek: !!!
  28. fordcpe
    fordcpe
    My car is different from front to rear looking.From the back it looks good with rake. From the front it looks level.I am waiting two years now for diamond back tires to make bigger 225 or235/75R14 tires only go to 215 now.That will bring me up and the 3/4" spacer over the rear buggy spring should help.My rear is 8" ford with not reverse buggy spring with 32 rubber frame bumpers with two big people in rumble it bottoms out a little on bumpers top of pig touchs the floor very little. Front is Rev. spring eyed with 4 inch droped axle and 195/75R14 Diamond back tires.Rear spring is no were near hitting and it has around 1 1/2" clearance from rear rubber bumper to top of rear axle.Darrell
  29. Stock front axle dropped 4 inches, reversed eyes, 3 leafs removed, unsplit wishbone. Reversed eye rear spring, 3 leafs removed, and drop shackles. 7.50 16"s and 5.50 16's.
