Projects new to H.A.M.B, wanted to share my project.
Discussion in 'The Hokey Ass Message Board' started by mjhartz87, Oct 8, 2013.
  1. 5window
    5window
    Welcome to the HAMB just don't mention it if you put a D***** in there. Kind of like saying R**R** and then your thread will be gone and we'll miss your great build.
    You're right, those photos show there's no room under that wheel.
  2. mjhartz87
    mjhartz87
    from Conroe TX
    I will admit I've seen worse but unfortunately all the rusted parts are where fisher rolled the bottom bead along the cab. I still haven't figured out what I'm going to do
  3. mjhartz87
    mjhartz87
    from Conroe TX
    Started doing a little mock up today so I can figure out motor placement. Using the 38 1.5 ton ch***is is not so bad after all. Aside from running board brackets. After doing the mock up today I realize that the original crossmember that held the radiator grill support has to be removed or notched to allow clearance for the 36 lower valance/splash apron. But I still continued mocking up and I'll deal with that part later.
    Sorry for the messy shop. It was an old horse barn that I've converted into a shop. I just recently did spring cleaning in the house and moved outta storage so it's a mess! Not to mention it has about 3 truckloads of stuff needing to go to donation. I finally convinced my fiancé she has to much ****.
  4. 65gregg
    65gregg
    from Willis, TX
    Welcome neighbor, great start.
  5. mjhartz87
    mjhartz87
    from Conroe TX
    neighbors we are. i think we are going to have to get together sometime.. wouldnt mind havin a local street rodder down the road
  6. mjhartz87
    mjhartz87
    from Conroe TX
    i recieved the motor mounts today in the mail.. no need to keep secrets as i will be setting up for sbc/bbc. i would love to do a standard trans but with how limited comfort and movement are i will be using a th 400.
  7. wingedexpress
    wingedexpress
    Nice looking old truck.
  8. mjhartz87
    mjhartz87
    from Conroe TX
    does anyone have any dimensions they can shoot my way of where exactly the front perch mounts?? i can get it close but no cigar. mainly im looking at the span from the firewall to the perch location for the radiator bracketry.
    thanks.
  9. bartmcneill
    bartmcneill
    from Ada, OK
    Nice old truck. I looked for a cab like that, had all the rest but gave up and sold the truck. Had a 34-5 high top cab on it with a home made back.
  10. Hdonlybob
    Hdonlybob
    Add another welcome from a Wisconsin guy !
    And nice project..
  11. I'll be the ***hole that points out your welds look like ****. I hope you redo them making sure you have adequate penetration and build. Other than that cool project!
  12. mjhartz87
    mjhartz87
    from Conroe TX
    thank you very much gents!
  13. skippycraig
    skippycraig
    from Washington
    Love the truck project! I can get some measurements for your core support. Give me a day or two. Craig
    Sent from my GT-P3113 using H.A.M.B. mobile app
  14. mjhartz87
    mjhartz87
    from Conroe TX
    yes yes they do. but they provided the penetration i needed. when i welded the crossmember in at the time i was using flux cored wire at which i cannot lay down for the life of me. ya'll can say what you want about them but they will hold and this is no trailer queen.. it will be a daily driver that i will drive the piss out of it...
  15. mjhartz87
    mjhartz87
    from Conroe TX
    thanks craig. i do appreciate the help!
  16. lucky-13
    lucky-13
    from Sacramento
    Shoot me a private message with your email and I will send you over all the measurements
  17. mgtstumpy
    mgtstumpy
    love that Chevy, can't wait to see it finished.
  18. timwhit
    timwhit
    Nice lines on the truck. BTW..there is "white firewall" thread now. tim
  19. nunattax
    nunattax
    like your build. im in the 30s chevy camp too
  20. walter
    walter
    Great Job!!. Love the look.
    Walter
  21. 72yenkonova
    72yenkonova
    WELCOME!! I just got a 1938 Chevy business coupe & it will be road ready very soon.
    Good Luck with the build & have fun with it.
    David
