Odd Flathead 8 Has Me Stumped
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by flyingblind, Apr 19, 2014.
  1. flyingblind
    flyingblind
    from alaska
    Came across this old Flat head V8 still in a partial chassis while spring skiing. It was used to run mining equipment in the mountains of Alaska. Have not been able to find anything like it. Delco distributor mounted on the front of the engine. Exhaust manifolds between the heads discharging into a common pipe to the rear, pipes may be home wrought as the brazing is still visible. Intake manifolds appear to be built into the heads. Chrome or stainless steering column is bent back to face out the front. Has a series of small valve cups on the top of the head, could have been for oiling? Anyone help identify this odd eight?
  2. cmyhtrod
    cmyhtrod
    from ct
    I'm thinking mid 30's Cadillac
  3. Lost in the Fifties
    Lost in the Fifties
    Agree on the Cadillac I.D.
  4. ill bet that motor worked its ass off in the day
  5. flyingblind
    flyingblind
    from alaska
  6. cmyhtrod
    cmyhtrod
    from ct
    I'd go get it
  7. Its an early lincoln, 1919 to early 30's probably. Not good for much than a restoration as parts are non-existant.
