Projects I'm all in...My '38 Chevy PU Build Thread
Discussion in 'The Hokey Ass Message Board' started by pila38, Aug 2, 2013.
  1. bengeltiger
    bengeltiger
    Where there's a will, there's a way. My single car garage is so small that I have to fold the mirrors in on my OT truck to put it in there. As a result my on topic car, a Falcon, resides on the driveway waiting for my attention when life permits. Just keep plugging and you'll get there in the end.
    (Subscribed!)
    pila38 likes this.
  2. pila38
    pila38
    ImageUploadedByH.A.M.B.1385236063.085140.jpg ImageUploadedByH.A.M.B.1385236073.553622.jpg ImageUploadedByH.A.M.B.1385236088.208473.jpg Didn't get any work done, but did do some dreamin' today. Here's the pics.
  3. lucky-13
    lucky-13
    from Sacramento
    Saw you want to run pie crusts if at all possible stay away from coker, very bad tire, hurst have had great reviews
  4. pila38
    pila38
    Was probably going to use the towel city 29 x 9. I heard good things, they come in the width i want, and its cheaper than the hursts.
  5. lucky-13
    lucky-13
    from Sacramento
    ya i agree the guys at towel city are good guys
  6. swade41
    swade41
    from Buffalo,NY
    Nothing wrong with dreaming, it keeps you motivated. At one point I had a tunnel ram small block in my truck, I think that tunnel ram got "dream" placed in about 3 different trucks. ha ha
    pila38 likes this.
  7. pila38
    pila38
    Haha! It seems like I spend too much time dreamin, and not enough time working!
  8. swade41
    swade41
    from Buffalo,NY
    Found this old picture of the tunnel ram small block in my 41
  9. pila38
    pila38
    Now that looks like a lot of fun! I'm jealous though, it has wheels and tires...another dream of mine.
  10. pila38
    pila38
    So...its been awhile since I last updated this thread. Not that I haven't been working on it, I just got very into what I'm doing and don't take pics. Anyways, I finally finished up welding the rear suspension in. I fish plated everything together and while it may not be fancy, it came out pretty good (except for the pics...they're awful!)
    And I know the angle is off from the fish plate and the gusset, but there was a major issue with the first gusset that had to get cut off and then I f'ed the angle on this one and didn't realize until too late.
    The rest of the plates:
  11. pila38
    pila38
    Check me out with photobucket now! Anywho...it's too damn cold out to be working in an unheated garage, so I set myself up with a little shop in the ba*****t. Warm...and I can work at night without ******* off my neighbors.
    It's a great place to do winter projects. I rebuilt the '42-'46 GM Saginaw recirculating ball steering box I will be using. Sorry didn't take pics of the process.
    And pressed the kingpins out the axle.
    Other winter projects will be to finish the kingpins and put the front shock mounts in the axle. I'll also be rebuilding the Olds third member since I got weak in the knees and ordered the 4.10s. Maybe I'll remember to take pics of that!
  12. pila38
    pila38
    Time for another update:
    Went to work on the front shock mounts in the axle. Drilled a hole where I wanted to install the mount:
    Then, I cut some 3/4" tubing to the length I wanted. One side was tapped 1/2"-20 for the shock studs. The other side was tapped 1/2"-13, a bolt was put in, and the head was cut off. This side will be rosette welded on the back side of the axle.
    Then, I beat them into where I wanted them. I did not weld them today, felt it was a little too chilly for it.
    Finally, I guess I got a little carried away with the drill press, because all of a sudden more holes appeared. I know, it's a full fender vehicle, kind of pointless...I just wanted to.
    Got two holes done, just seven more to go!
  13. nhmikel
    nhmikel
    from NH
    Sweet ...glad to see your at it....hopefully I will be back at it as well
    pila38 likes this.
  14. pila38
    pila38
    Thanks man, definitely feels good to make progress.
  15. nunattax
    nunattax
    eric nice to see you are moving along again.
    pila38 likes this.
  16. pila38
    pila38
    Thanks Chris. Hopefully I can keep it going for a while.
  17. pila38
    pila38
    ImageUploadedByH.A.M.B.1399250772.907279.jpg ImageUploadedByH.A.M.B.1399250781.408745.jpg ImageUploadedByH.A.M.B.1399250791.639321.jpg 7 down, 2 more to go. ImageUploadedByH.A.M.B.1399250772.907279.jpg ImageUploadedByH.A.M.B.1399250781.408745.jpg ImageUploadedByH.A.M.B.1399250791.639321.jpg
  18. pila38
    pila38
    ImageUploadedByH.A.M.B.1399338042.443313.jpg ImageUploadedByH.A.M.B.1399338056.076566.jpg ImageUploadedByH.A.M.B.1399338067.058797.jpg Cross one more thing off the list.
  19. lucky-13
    lucky-13
    from Sacramento
    looking good man, cool truck. keep at it they come together in the end
    pila38 likes this.
  20. pila38
    pila38
    Thanks Lucky. UPDATES!! Made some progress lately, but no pics to prove it. Sorry. After A LOT of measuring, I'm finally ready to nail down the engine and trans mounts. Made some bump stops for the rear shocks out of hockey pucks. Got all of the steering hooked up and it works (at least in mock up mode). And I started fabricating the upper shock mounts in the front. I also ordered the rear tires and wheels, which should be here within the month. I also laid out the hole sizes for drilling the frame. I'll try to put up some pics soon.
  21. pila38
    pila38
    So...no pics of the others stuff, however, I did start drilling the frame and I actually did take pics of it! It's a very time consuming process and probably the most physically demanding job I've done on this truck yet. Most of that is thanks to my grandfather's old drill. It's got a ton of torque, but god damn, if it catches wrong it'll rip you arm right off. I got a few good bruises on my stomach from it.
    Here's the offender:
  22. pila38
    pila38
    Whoops! Hit reply to fast. Any way, here's the drill:[​IMG]
    And here's the damage it did:
  23. pila38
    pila38
    Got a lot done this weekend. Finished drilling the frame, glad to be done with that job. Also, fabbed up some upper shock mounts from 1/8" plate.
    My wheels and tires for the rear came, so got them mounted and put them on the truck.
    I'm pumped, it's the first time the truck has been on all fours in over 15 years! She even got to see some daylight for the first time in five years.
    Do you really care what I used to post this message?
  24. 3R CRUZER
    3R CRUZER
    from Kerman Ca.
    Looks good great job
    pila38 likes this.
  25. pila38
    pila38
    Thanks Cruzer!
  26. TFoch
    TFoch
    Love those rear wheels and tires! Really makes the truck. Nice progress!
    pila38 likes this.
  27. pila38
    pila38
    Thanks man, I really couldn't picture it with any other wheel/tire combo on the back. It looks killer with the rear fender mocked up too, I can't wait to get a bed on it!
  28. K13
    K13
    Looking good! I agree I like the wheel and tire combo.
    pila38 likes this.
  29. pila38
    pila38
    Appreciate the kind words K13! It will look real good with the polished kidney bean wheels in the front as well. They're just not in the budget quite yet!
  30. swade41
    swade41
    from Buffalo,NY
    Nice to see an update, the frame holes look killer as do the rear rolling stock !
    pila38 likes this.
