Technical Wire wheel or sandblast
Discussion in 'The Hokey Ass Message Board' started by jesse1980, Apr 19, 2014.
  1. jesse1980
    jesse1980
    Was just wondering, I'm getting ready to clean up my frame for my catalina and I was going to wire wheel the whole thing and paint it, or is sandblasting better. The frame is bare, I have the body off of it. Thanks for your input.
  2. chopolds
    chopolds
    from howell, nj
    If there's a choice, blasting always works better.
  3. jesse1980
    jesse1980
    Yeah, I was going to drop it off to a place for 300.00 to blast it, but my buddy who has done a few frames said wire wheel is better. Either way is fine with me, just want it to come out nice is all.
  4. Frankenstein57
    Frankenstein57
    I would blast it, then I use rust seal from KBS coatings. A little more $$$ than paint, but much better results, Mark
  5. jesse1980
    jesse1980
    Sounds like I'll be sandblasting it.
  6. squirrel
    If I had to pay $300 to get it blasted, I'd think twice...but since I can do it myself for less than $50, I'd blast it.
    so it's hard to answer your question.
  7. jesse1980
    jesse1980
    I can wire wheel it free here at my house. My blaster is kinda small. I plan on building more cars so maybe I should invest in a blaster
  8. The37Kid
    The37Kid
    Either way be sure to degrease it first, you'll have a better frame after it gets blasted. Bob
  9. jesse1980
    jesse1980
    Absolutely. I just got a new power washer
  10. the frame is out from the car , it's the time to sand blast it and do it right
  11. HOTRODPRIMER
    HOTRODPRIMER
    Your friend is nuts,wire wheels will take a lot of time and wont get all the hard to reach areas.
    Small sandblasters can be had for just over a hundred bucks and fine sand is not that expensive,,I have had mine for years.
    If you decide to do your own sandblasting,,please invest in a good respirator,you don't want the silica dust in your lungs.
    If you have a small compressor it will run constantly and you'll have to stop and let it catch up,,but you can do the job.
    I did the entire wagon & frame with a small sandblaster. HRP
  12. TagMan
    TagMan
    Blasting for sure, but I definitely wouldn't use the "wet blast" system, which uses a jet of sand borne water. The idea is that the water would prevent any warping of the sheet metal.
    A friend of mine had the hood from his '58 Chevy 1/2T blasted and the pressure was so high, it warped the hood terribly. He also had the cab blasted and two weeks later, we're still digging wet, compacted sand out of the numerous cavities. A total pain the ***.
  13. pimpin paint
    pimpin paint
    from so cal
    Hey,
    As the kiddies say, '' it's a no brainer "!................wet blast or wire wheel??!! Ya gotta be jokein' me?
    For $300.00 the guy's gonna blast all the old paint, rust & **** from your frame, ***ume all the health risks that detail involves, and handle the clean up after he's done??? Load your frame up, and take it to him before he comes to his senses!
    Besure to lightly sand your frame prior to primering to dislodge any bits of sand left in the grains of the metal, and prime the day the frame is blasted.
  14. A Rodder
    A Rodder
    Isn't that ^^^^ potentially true with regular sand blasting as well, the potential of warping?
    I looked at a a friend's Model A Woody yesterday who just had all the metal parts wet blasted and laid out.
    He was extremely happy.
  15. HOTRODPRIMER
    HOTRODPRIMER
    The OP said said blasting,not wet blasting also he is talking about the frame. HRP
  16. The37Kid
    The37Kid
    Wet blasting? Never heard about that except for aluminum castings in a cabinet. Be sure to buy your primer and related thinner before you get the frame blasted so you are ready to prime it when it is returned. Ever meet someone with the ability to leave finger or hand prints on freshly blasted parts? Don't know what that medical condition is, but keep them away from unprimed metal. Bob
  17. jesse1980
    jesse1980
    Thanks for straightening that out.
  18. bako48
    bako48
    Dry blast it with 30/60 mesh sand but get SAND not the steel shot or coal slag style stuff the sand with leave a smooth profile on it and like said above go over it with just some 80 grit on a DA sander. The steel shot will actually leave craters in it making it look similar to orange peel on the surface. The coal slag is real sharp and when painted itll look like you left dirt on with a grainy finish. For that price also get it over there ASAP!!! Before he changes his mind.
  19. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Labor rates must be low in your area. For $300 he's doing it cheap! With all the labor involved, you'll be doing the job yourself with a wire wheel for $10 or so an hour and it's hellacious labor. Think how much other work you can get done on the car in a couple of days with your time.
    Ask your friend how much he'd charge to wire wheel your frame clean.
  20. HOTRODPRIMER
    HOTRODPRIMER
    I have always bought my sand in 50 lb. bags and purchased them at a local facility that sells concrete and block,,they carry sand blasting sand in very fine, fine and course.
    Make sure the sand is stored in a dry place. HRP
  21. TagMan
    TagMan
    Just adding a caveat that someone else might appreciate. I'll check with you before posting next time............:D
  22. HOTRODPRIMER
    HOTRODPRIMER
    Proviso of specific stipulations,,I like that. HRP
  23. 28rpu
    28rpu
    Are there any powder coaters in your area? Get a price from them.
    I got a frame sand blasted and powder coated for $400.
  24. I have a wet blaster that uses recycled bottle gl*** and at least 100 cfm of air at 120psi. I did a camero sub frame for 300$ just last week.
  25. Ulu
    Ulu
    from CenCal
    I'm a DIY freak. I don't want other people working on my stuff.
    However, the last frame I blasted, I used a 100 HP compressor, and it took me all day including the towing and cleanup.
    My friend works at a structural steel fabricator with a 600 HP compressor (!) and that thing will do a whole frame in under 60 minutes. (Unfortunately he can't get me in there anymore.)
    My home compressor is a cast iron 1/2 hp 1960's I-R which has been faithful for 35 years, but only does 4 CFM at 100 psi & will take about 3 weeks. :eek:
    Plus I live in the suburbs, so my neighbors might get a bit stuffy if I rent a 200 HP diesel compressor & crank it up in the back yard for 5 hours.
    I'm afraid I'll be sending mine out to be blasted & painted. ;)
  26. jesse1980
    jesse1980
    I like doing stuff myself also. I have a small blaster that holds 50lbs of blast. I already have two bags of blast sittin too. The only problem I have is a air line dryer, that's what messed me up when I was doing my intake. It kept getting clogged. Also like HRP said I need to get some sort of respirator.
  27. ChanceDean
    ChanceDean
    The Catalina wine mixer? 😆
    Sandblasting is always a good choice when I comes to getting a frame done, smaller things such as front axels or rear housings are quicker with a wire wheel
  28. HOTRODPRIMER
    HOTRODPRIMER
    I have a air drier also but that should help instead of hurt,,sometimes you just need to adjust the valve at the bottom of your blaster. HRP
  29. Ulu
    Ulu
    from CenCal
    You really do need a big drier when blasting, and remember to drain the compressor tank too. Also drain your hoses. Not uncommon for water to build up inside the hoses.
    Damp sand is a total nuisance. Get it really dry before using.
    I do hate sandblasting, but I'm going to set up a small blast cabinet to do some little parts. No way can I sandblast anything big with my setup.
  30. 31Apickup
    31Apickup
    Have the frame blasted. For those who have issues with the air line dryer, you need to have about 12 feet of steel pipe between the dryer and the compressor so that the moisture can condense and the dryer work properly. If you have it mounted right at the compressor, it's never going to work.
