Technical Model A Delivery...What Doors?...
Discussion in 'The Hokey Ass Message Board' started by MrGasser, Mar 28, 2014.
  1. MrGasser
    MrGasser
    from DETROIT
    ...did they use coupe, truck, Fordor front doors?...
  2. kb cookout
    kb cookout
    On
    1928-29 they used 2 door sedan / coupe cowls and 2 door sedan and coupe doors
    on
    1930 -31 they used a sedan/ pickup cowls and 2 door sedan and pickup doors
    Panel delivery are different too
    later kb
  3. metalman
    metalman
    KB your info is confusing, arn't coupe, sedans and pick up doors all different?
    Mr g***er, a sedan delivery or a panel delivery (truck)?
    My understanding is 28/29 sedan deliverys used sedan doors, all panel trucks used truck doors. There was no factory sedan deliverys in 30/31, just panel trucks.
  4. Corn Fed
    Corn Fed
    KB is correct in what he said about the doors. 28/9 PU doors are different than Tudor Sedan/Coupe. 30/1 coupe are different than Tudor & PU.
    Your understanding of 28/9 deliveries & panels is correct as well.
  5. oldgoaly
    oldgoaly
    damn I have 2- 30 sedan deliveries, but I don't know what door interchange?
  6. Atwater Mike
    Atwater Mike
  7. kb cookout
    kb cookout
    Well I must have been dreaming when I rebuild this one it's a 1930 deluxe delivery
    I need to start a thread on 1928-1931 sedan deliverys and panel deliverys, I have built and worked on a doz or so of them all year and style and a few 1932- 1948
    later kb
    Later kb
  8. metalman
    metalman
    Yes, that's a 30/31 but not a sedan delivery, thats a truck based panel.
    To me a sedan delivery is a standard Tudor with the 1/4 windows blanked out and a rear door added, other wise known as the Type 130A Deluxe Delivery Car in 28/29. In 30/31 it was replaced with the Type 130B and had it's own body, not a modified Tudor , it was bigger, and considered a truck. That's what you have pictured here In 1932 the Type 130-B went back to being based on a modified Tudor body. Being based on a Tudor or truck is what I'm referring to, not the name "Deluxe Delivery car".
  9. Corn Fed
    Corn Fed
    I think your reasoning is wrong because if Sedan Deliveries where only slightly modified Tudors, there would be no sedan deliveries after 1932, all would be Panel trucks. I would argue that the most widely accepted definition of a Delivery vs a Panel is if it has 1 rear door (Delivery) or 2 rear doors (Panel). Now there may be some flukes out there where a special Panel had a single rear door, but that is the exception not the rule.
  10. metalman
    metalman
    OK, guess I'll clarify what I'm saying. I agree generally sedan deliverys have one door, Panel trucks have 2. Regardless of the name I was just pointing out 28/29 and 32 were modified Tudor bodies, the other years they hade a body that was all their own, didn't share 1/4 panels and such with the Tudor. That's why I was asking what year the op had. If his is a 28/29 we know it uses Tudor doors, admittally I don't know which doors Ford used on the 30/31.
    FWIW the 33 on Sedan Deliveries did have their own Ford built bodies but apparently a few Tudors in 33/34 were modified into delveries by an outside vender (Briggs I think, and if I remember right they were mostly for Nation Cash Register service fleet) so one might run across a Tudor based delivery, which would be quite the find!
  11. MrGasser
    MrGasser
    from DETROIT
    OK, these are the quarter panels I have, (the lower corner is there, not missing, just bent in slightly)...I'm ***uming these are '30-'31 panel truck?
      120 KB
  12. bowie
    bowie
    Mr g***er: Those quarters sure look like 30-31 sedan delivery to me. I have a 31 panel, and the top rear is very squared off. Also the panel truck appears taller.
  13. patterpillar
    patterpillar
    from Montana
    So what year may this Panel be? The front of the cowl looks 34 ish.
      441.3 KB
      439.6 KB
  14. bowie
    bowie
    patterpillar: Sure looks like a '35-'36 to me.
  15. oldgoaly
    oldgoaly
    agreed 35 or 36, 35 grille is thinner and the hood badges are in different places
    37 is a solid roof, grille and hoods are different
  16. 30panel
    30panel
    Here's my 31 Panel Truck 79B.
    <input id="mac_address" value="" type="hidden"><input id="mac_address" value="" type="hidden"><input id="mac_address" value="" type="hidden"><input id="mac_address" value="" type="hidden">
