Hello from Colorado 1955 plaza plymouth Engine # P27-217694 Try to figure out if it is a 241 or a 259 Any help would be appreciated. It has been on blocks since 1973.. Thanks, Derek
As you may already know P-27 was used for both engines. Might try the casting number, I'm ***uming they are different between the 2, if not you'd have to measure the bore. 241 is 3.4385 259 is 3.5625
I will be pulling the engine this next weekend. The number In the first post I think was the casting number. Engine # P27-217694 Thanks.
Casting number is on rear face of the block. I can't seem to find my ref with the poly casting numbers, not sure if 241 Poly has a different # than the 241 hemi. '55 Hemi would be 1632229 or 1635829
my ref doesn't show # for PLYMOUTH 241, only Dodge so I'm not sure if polys & hemis have the same casting #. dodge is 1409528 or 1613745 but those are listed for 53-4 dodges
