Projects 1936 Chevy build
Discussion in 'The Hokey Ass Message Board' started by lucky-13, Sep 11, 2013.
  1. lucky-13
    lucky-13
    from Sacramento
    here is a link to a weld in on that is almost identical to what i made pretty cheap too.
    http://www.speedwaymotors.com/Speedway-Weld-In-Battery-Box,3455.html
  2. jegbflat
    jegbflat
    Thanks for the battery location tips... in the setup above, could you share wheel and tire sizes? Great stance as others have noted.
    Thanks again, Jerry
  3. jegbflat
    jegbflat
    Hi again - I had kept a photo of your cab interior with this note about the seat you used. Returning home today, found my neighbor had put her '94 Mazda mpv rear bench seat out on the road with a "free" sign, haha. Anyway, remembering your post, I checked it out with a tape measure and it seemed a bit wide (48") and only seemed to fold down (backward) but not forward. When I told her what I wanted a seat for, she offered to let me have the middle bench if I'd reinstall the back one for her. It's narrower at about 42", but it does fold both forward and backward. Has head-rests and an armrest on passenger side. Is this pretty close to what you used? If so, I'll have to figure out how to mount it. Any advice or feedback would be greatly appreciated. Jerry
  4. lucky-13
    lucky-13
    from Sacramento
    well jerry im not sure about the middle row seat but i know my seat just tips forward by a little pull strap on the drivers side. As for the width the 48 did fit but each front corner did touch the door panels before i had the seat reupholstered, so the middle row might be more effective. As for mounting, what i did was steal the front mounts and those are bolted to the floor in the cab with a bunch of supports for strength. As for the back the mounts stock didnt work so what i did was used the stock 4 bolt hole that go up into the seat frame and made little mounts that bolt to the seat then bolt into the floor. by doing this i got the back of the seat lower then the front giving it some bucket, because of the chanel my floor is completely flat with no area for the gas tank below the seat. I like the third row better then the middle because it has no arm rests and the mounts are low profile due to the step in the floor of the mazda.
    As for the tires and wheels the wheels are all 15 inch jimmy 9 from rally america 8 inch in the back and 4 or 5 inch in the front. The overall tire size in the back is 30.5 and 25 in the front. All the tires are all coker bias ply the fronts work great but the back are terrible out of round and hard as a rock. If you want the same style back tires go with towel city or hurst much better overall tires.
  5. jegbflat
    jegbflat
    Thanks a ton for your replies - very much appreciated. I passed on the back seat because of the wide front - but sounds like you made it work until you "reupholstered" which is all I really want to do right now. Also passed because they didn't seem to fold forward, but I didn't see a strap like you mentioned. I'll take another look.
    Thanks again,
    jerry
  6. lucky-13
    lucky-13
    from Sacramento
    some up to date pictures of the truck
  7. lucky-13
    lucky-13
    from Sacramento
    Got my new hood emblem all fitted together. The top is from a 1934 Pontiac and the base I had to use my original one to fit the grill shell next is the rest of the emblems, handles and grill shell to prep for nickel plating
  8. nlualum82
    nlualum82
    from Oregon
    Great truck!
    Mine is the same model. Bed looks the same except mine is 62.5" long. I would've advised keeping the cowl vent, I like to open the windshield, cowl vent and both windows on hot days and wish I had a roll down back window ala Ford coupe.
  9. lucky-13
    lucky-13
    from Sacramento
    Ya I would have liked to keep the went but it was just way to far gone to save.
  10. treb11
    treb11
    Now that's a bobber truck I can like
  11. lucky-13
    lucky-13
    from Sacramento
    Thank you treb11. In all honesty I wasn't shooting for a bobber just built a safe well balanced truck.
  12. belair
    belair
    This one's been in the family since 1954. I broke the key off in the glove box in about 1961.
    charleyw and Roger53 like this.
  13. lucky-13
    lucky-13
    from Sacramento
    That is awesome. We are the third owners and we got it in the early 80's. Does your glove box have the clock in it?
    Roger53 likes this.
  14. belair
    belair
    No. I bet that was a big option for a truck back in the day. But you can see the hi-tech anti-theft device in the 2nd pic.
  15. lucky-13
    lucky-13
    from Sacramento
    Really nice truck I have always like these years all original as well.
  16. belair
    belair
    This one has a dropped axle, v-6, auto, a/c, etc. Might have been a plumber's truck, not sure on that. Used to have two side mounts, my dad has done all the work to the truck over the years, except for upholstery. He bought is as a rough roller in Waco, towed it home with the M/C tied to his foot.
  17. Wow, that thing looks great for something that you haven't been able to start since 1961!
    belair likes this.
  18. lucky-13
    lucky-13
    from Sacramento
    the glove box uses one key and the ignition is another I think
  19. nunattax
    nunattax
    nice build .glad to c the rad up front.can u post a pic of your throttle pedal placement.wheels look great black.chris
  20. lucky-13
    lucky-13
    from Sacramento
    Some of my current work on the 36 pre nickel plate with the new stainless insert
  21. lucky-13
    lucky-13
    from Sacramento
    Got everything back from San Joaquin chrome in Lodi they did an amazing job.
  22. Very nice truck sir, I have always like the year, and let me also say nicely done thread.
    lucky-13 likes this.
  23. lucky-13
    lucky-13
    from Sacramento
  24. belair
    belair
    Congratulations. Hope you're having fun with it.
  25. lucky-13
    lucky-13
    from Sacramento
    Thanks. Trying to get everything back together today . Just realized after all the recoating one headlight is slightly closer to the grill then the other so I might have to see if I can find adjustment somewhere.
  26. Roger53
    Roger53
    Hi You've put together one very nice chevy hot rod pickup. Roger
  27. lucky-13
    lucky-13
    from Sacramento
  28. katg67
    katg67
    Really Nice Job. Have fun with that ride!
  29. lucky-13
    lucky-13
    from Sacramento
  30. BillyBadA$$
    BillyBadA$$
    lucky-13: I understand you used a 46" front axle w/ 4" drop. What is your rear axle length?
    I was going to assume it is 56" if your front hub to hub length is around 54-1/4".
    I really like the truck and am in process of getting my axles and frame together now.
