Technical What kind of Tig Welder are you using
Discussion in 'The Hokey Ass Message Board' started by Sweet & Low, Apr 1, 2014.
  1. lowandslow60
    lowandslow60
    I love the Lincoln 175. It's a well-built machine. I went to Wyotech with lots of people using these machines on a daily basis and I never had a problem with a single one of them. (Tons of not-so-experienced students using them every day and no problems says a lot to Lincoln's quality.)
  2. BarryA
    BarryA
    I have one of those too and a bigger AC/DC machine (I added a foot pedal and water cooled torch) from the same manufacturer. Both have served me really well for close to 10 years now - mostly sheet metal but I do heavier stuff with them too.
    I'd love to have a Dynasty (used one on a trip to the US in 2008) but the local distributor puts a crazy mark up on Miller stuff making them more than double the cost of what you guys can get them for......
  3. pinkynoegg
    pinkynoegg
    another for the Eastwood 200. for the price, its hard to beat. especially for a shade-tree mechanic like myself
  4. spuds
    spuds
    from Idaho
    Miller Synchrowave 250 with cooler
  5. cktasto
    cktasto
    Miller dialarc
    Great machine, does anything i could need.
  6. INTMD8
    INTMD8
    from Il.
    I have a water cooled HTP invertig 221. Love everything about it.
  7. bobkatrods
    bobkatrods
    from aledo tx
    I have a miller 250 with bernard cooler works great, 2 years ago i was looking for something more portable , I bought a Everlast 200,, I was not sure about buying it, but it is a great machine with a better warranty than eastwood, Inverter Tig, I find myself using it more than my Miller,
  8. gow589gow
    gow589gow
    from Indiana
    Odd, I have never had a bit of trouble with mine.
  9. terry skinner
    terry skinner
    from Roy, WA
    I have a Lincoln Ideal Arc 250. Last of the copper core welders. Purchased it new in 1980 for $600 along with a Conley Kleppen water cooled torch. Had them so long that the expendables are getting hard to find..........Terry
    PS wouldn't part with it!!
  10. 340HilbornDuster
    340HilbornDuster
    ESAB 165 AC/DC inverter unit...(about ten years old)
    Doesn't have all the Bells & Whistles of todays machines ...
    But it's got HF start and it does everything I need.
    T
  11. hooliganshotrods
    hooliganshotrods
    Miller Dynasty 200 is a great machine.
  12. gimpyshotrods
    gimpyshotrods
    Same here. Rock solid.
  13. mink
    mink
    from CT
    Miller Diversion 180. 50lbs ,very portable and affordable
  14. timothale
    timothale
    I have an old Airco AC DC HI freq from the college when the instructor retired and they shut down the program. It's good for heavy tig work, and I can stick with Hi Feeq. A few years ago I bought a used Lincoln 255 Tig with thumb control water cooled torch, It will also do Ac& dc, aluminum, stick but takes a while to change cables. The Linclon has ac balance control, and pulse. It is a big heavy machine. I haven't done any thin stuff with it.
  15. 340HilbornDuster
    340HilbornDuster
    I'm just getting ready to weld up my whole frame...
    GONNA GET HOT!
    Have anyone converted their TIG torch to water cooled?
    AND run regular tap water through it..?
    I can get the complete torch (WP18) with connectors for under 100bucks.
    The Cooling / Pump device sells for $500 and UP.
    TEMPORARY
    I plan to use this only when doing a lot of welding.
    T
  16. gow589gow
    gow589gow
    from Indiana
    Fan was not needed. Even on heavy aluminum welding or extended welding:
  17. rodbiz
    rodbiz
    from Illinois
    Miller Synchrowave 250 with water. Great machine!
  18. dirt t
    dirt t
    1. HAMB Old Farts' Club
    Me too.
  19. A Miller Dynasty 200 works great for me. I mostly do sheet metal and fabrication of small parts under 1/8" thick. It is slow, but I enjoy using it and now rarely use my Lincoln MIG.
    It is probably too small to build a full frame, but that is something I would want someone who is a really good welder to finish weld for me.
  20. cayager
    cayager
    I have a dynasty 200 and a little older dynasty 300. Just sold a sync 250. great machine. Both water cooled. Alot of money for a hobbiest though. If your not using them all the time.
  21. I used what they don't recommend, 50/50 mix green coolant/distilled water, seems to work fine, idk, chemical makeup is the same as the over-the-counter recommended torch cooler coolant. Never had any issues with it..
  22. No Plan
    No Plan
    Lincoln 185 pro, I love it.
  23. gary terhaar
    gary terhaar
    from oakdale ny
    Have a miller synchro wave 300 and use green in the cooler for years. Used the glycol coolent on my ideal arc 300 at home and a fungus grew from being stagnant,cooked the cable fast when it clogged the hose.
    Not to mention the white slime snake I had to clean out of it.
    Both machines are old but use transformer technology,you have to hit it with lightning to kill them.
    Using them both for 25 plus years,no problems.
  24. Babyearl
    Babyearl
    Lincoln 175 square wave no problems.
  25. Hemi j
    Hemi j
    from Colorado
    Linde 250, I've owned it over 25 years, what a killer machine, to bad they don't make them anymore. I have a Linde mig also!
  26. tig master
    tig master
    from up north
    Dynasty 200 dx uses any power you have. Water cooled weld craft crafter torch.
    Home grown cooler.Has good warranty program and parts are available.Yes they are expensive but very very smooth machine.Wireless remote.Its my third Miller..
    T
  27. fatkoop
    fatkoop
    Miller Dialarc 250 with Bernard water cooler. Been using this same machine more than 30 years and it still welds like new. Never had a problem with it.
  28. stimpy
    stimpy
    I heard storys like this , when I had the shop it wasn't a problem as the unit got used atleast once a week , when I closed and brought the machine home , I drained the tank and just used distilled water and would drain it back into the jugs when I was done . also I added a surfacant to break the oxygen bubbles out of it . and a case of Distilled isn't that expensive , compaired to a fubared transfer line . I know of one guy who runs a water cooler that put a DI filter ( deionized water) on his supply line to top the unit up . no mineral scale or iron problems .
