History Guess what? another survivor hot rod is unearthed!
Discussion in 'Traditional Hot Rods' started by titus, Jan 12, 2014.
  1. Black is best for busy exposed engines!
    Looking good Jeff!
    Posted using Full box of Crayons on the Kitchen Walls App!
  2. Rocky
    Rocky
    Classified Editor
    Super cool! I always wanted a hotord with a 324 Olds/slant pan hydro in it after owning both a 55 and a 56 Olds.
    I yanked the 324 outta my 56 olds 98 rag top to put in a super cherry pie 50 ford tudor sedan but went in the service before I could finish it. Glad to see you are gonna get an olds powered hotrod on the street. I want a ride in it the next time I get up there, Jeff.
  3. titus
    titus
    Yes if you want to get technical, thats why i said they are basically the same, drilling a few holes in my book doesnt make them different.
    jeff
  4. fleetside66
    fleetside66
    I'm adding it to my Ford 32-34 fenderless truck survivor pic collection. Every once in a while someone comes along doubting they ever existed back in the day & lay all the pics on them. What a great little hot rod!
  5. titus
    titus
    Been kinda hopping back and forth working on this any my 34 5 window, so yesterday we worked on the truck all day, got alot of putsy stuff done but its coming along nicely. got the steering box mounting reinforcement plate/extra hole cover plate done out of stainless, still have to polish it. got some radiator suport rods installed also, made some exhaust flanges made for the manifolds as no one sells anything that fits or works good. got the other firewall reinforcement peice done along with some dash braces too, worked on mocking up the pullys and generator brackets and mesured up some belts too, got the lower hose figured out, and started work on the upper, we took a couple of the water block offs for the heads and drilled and tapped them to 1/2 npt, then screwed in some 1/2 npt to 3/4 hose fittings, then picked up a offy remote stat housing and stuck a couple more fittings into that, then got a pair of molded 90 degree heater hoses and cut those off to fit, walla a water cross over for an olds. also finished fixing the grille shell up and bead blasted it getting it ready for body work.
    downsized_0327040937.jpg downsized_0327040938.jpg downsized_0327041852.jpg downsized_0327041852a.jpg downsized_0327041853.jpg downsized_0327041853a.jpg downsized_0327041855.jpg downsized_0327041856.jpg downsized_0327041856a.jpg downsized_0327041858a.jpg downsized_0327042106.jpg
    kidcampbell71, kiwijeff and Hotrodmyk like this.
  6. titus
    titus
    been working alot on both the 34s, got a bunch of stuff done on this one today, got the stainless firewall panel cut out and painted behind it and reinstalled it, got he heads back on the motor, got the dash all fully welded and ground, floors finish welded and seam sealed in etc etc.
    downsized_0331041613.jpg downsized_0331041644.jpg downsized_0331041749(1).jpg downsized_0331041750.jpg downsized_0331041514.jpg
  7. titus
    titus
    got more stuf done, motor is all together and painted, got the grille and dash bodyworked, primed, based and cleared today too, gonna start bolting it all together tomorrow. also got the floors all painted up yesterday too and painted teh frame up where the xmember was repair, and put the carb back on but havent gotten to many pics of that yet.
    jeff
    0402040428a.jpg downsized_0402041403.jpg downsized_0402041404.jpg downsized_0401041503.jpg downsized_0401041016.jpg downsized_0401040905.jpg
    kidcampbell71 likes this.
  8. titus
    titus
    its mostly ready for the show.
  9. What a sweet little truck!
    Great work as usual.
  10. fleetside66
    fleetside66
    So, what gauge antiquities are you using?
  11. Hotrodmyk
    Hotrodmyk
    Very cool build, love the truck.
  12. waxhead
    waxhead
    from West Oz
    Coming along nicely, looks good.
  13. John 79
    John 79
    from Sweden
    Really nice truck!
  14. titus
    titus
    heres a few more pics before we carted it off to gsta and in my display at the GSTA
    10171103_831513096875208_911323228_n.jpg 10171177_831513136875204_1956478799_n.jpg 1604744_831620150197836_308338090_n.jpg 10155006_831621820197669_997281204_n.jpg
    kidcampbell71 and kiwijeff like this.
  15. titus
    titus
    Been super busy and havent had time to post many pics, or even take many pics, we fired it up today and it seems to run pretty good. All the brakes lines are done and brakes are all rebuilt and bled, clutch set up it all done and working, wiring is all done including all the gauges etc etc, got the gas tank done the other day (ill get some pics of that tomorrow) and have it all mounted too, so its getting really close, we are planning on bringing it to Torque fest on friday.
    JEFF
    downsized_0421141352.jpg downsized_0424141024.jpg downsized_0418141023.jpg downsized_0418141221(1).jpg downsized_0418141547.jpg 0418141027.jpg 0428142311.jpg downsized_0428142310.jpg downsized_0428142313.jpg
  16. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    This truck rules!!
    Great job Jeff- can't wait to see it in person-
    Tuck
  17. Nice job, very cool!!!!
  18. titus
    titus
    well we got it on the road, im gonna do an update with pics and a video soon here, got back from torque fest late late saturday night, unfortunately we had to trailor it down to the shop, but we unloaded it at the hotel and drove it form there to the show so we got a few miles on it, we just ran out of time to road worthy it and didnt want to take a chance on hurting anything on the motor. it was the same thing with my hemi powered 34 coupe.
    JEFF
    kidcampbell71, kiwijeff and Jeff34 like this.
  19. titus
    titus
  20. pitman
    pitman
    Looking just fine!
    Thanks for the 'drive'.
  21. Paul
    Paul
    Editor
    like the opening scene to Hotrod to Hell
  22. Speedy Canuck
    Speedy Canuck
    Looking great Jeff! Both of them are.
    Question for you. Is that a drivers side manifold on the p***enger side? How does the exhaust work with the oil filter (or starter if it's been relocated)?
  23. titus
    titus
    the manifolds are in their stock location as far as i know, it has a oil filter byp*** on it with the starter relocator and it all fits fine.
  24. Low Black Special
    Low Black Special
    from SE Iowa
    I saw this little truck at torque fest, and the 34 too. Looking great.
  25. Many of us NEWBYS to the hot rod scene did not build cars very well in the late 50's and 60's as we were LEARNING from the little books!!!! Page by page. Most of us had to find someoe with a welder or a torch. Many bodies were just dropped and holes drilled in the frame and the bodies just bolted on. Not correct nor safe by any means!!!! But we had a dream. We found an old car or truck like those in the little book and we liked it and imagined our driving around town in it. A LOT of those dreams were never accomplished. Just dreams. You have found one of those cars!!! Now finish it into REALITY!!!
  26. Speedy Canuck
    Speedy Canuck
    Interesting. Thanks Jeff.
    Good video of it going for a blast :D
  27. Paul
    Paul
    Editor
    must be using the early 303 exhaust manifolds then?
    man I love this truck,
    I've read and reread this thread and watched the video several times..
    late '50s early '60s style just seems so right to me
    and you are making that one perfect
  28. Speedy Canuck
    Speedy Canuck
    That's what I was thinking. Too bad that both sides weren't front dump like the drivers side is... That's what I need.
  29. titus
    titus
    Chad has been driving the truck regularily, there was an engine issue, seems the rings in on cylinder decided to give out so they were replaced the motor runs good, he had it out to Back to the Fifties, and lately to the Minneapolis Messaround.
  30. kidcampbell71
    kidcampbell71
    Nice. Was cringing until I saw you polishing the firewall. I have a thing for flat firewalls...hate them....unless polished or engine turned !! That thing looks better then ever, but of course.....you already know !! On with the show........thank you.
