Technical Having fuel problems
Discussion in 'The Hokey Ass Message Board' started by sp1ke, Apr 28, 2014.
  1. sp1ke
    sp1ke
    I have a 255 m
    cu.in Merc. flathead stock with the exceptions of offy heads and intake with a tpot holly 4 barrel 390 cfm I believe. I have an electric fuel pump but I can only go about 5 miles before I seem to run out gas however gas tank is full and clean and all filters are clean any answers???
  2. Normal Norman
    Normal Norman
    from Goshen IN.
    Are you certain it is a fuel problem then? Have you disconnected the fuel line at the carb to see if it is still pushing fuel? I had a Ford Bronco some years ago that had a bad ign. coil that did that, it had me chasing my tail awhile before I got that one figured out. N.N.
  3. flamed34
    flamed34
    Is there a sock filter on the pickup in the tank?
  4. AnimalAin
    AnimalAin
    Is the tank vent clear? The pump won't work if you can't replace the gas going out with some air coming in.
  5. landseaandair
    landseaandair
    from phoenix
    That and cracks or pinholes in the rear hose, pick up tube or plugged vent.
  6. Boyd Wylie
    Boyd Wylie
    I'll suggest checking for proper venting.Try going for a drive with the gas cap off.
  7. oldsjoe
    oldsjoe
    Rubber fuel line collapsing from suction? This **** they p*** on to us as fuel just eats up rubber parts.
  8. unkledaddy
    unkledaddy
    Any inline filter that needs cleaned?
  9. brokenspoke
    brokenspoke
    I have always been told most fuel problems are electrical
  10. sp1ke
    sp1ke
    Venting seems to be the problem.Went for a drive with the g*** cap off and never quit at all.now what is the best way to restore the vent. Is it possible to drill a couple of 1/8 inch holes below the cap or what/ Thanks guys for all your help--spike
  11. 59Apachegail
    59Apachegail
    from New York
    Might be better just to get a venting gas cap. I had a similar issue and I used a thermal sleeve around the fuel line from pump to carb. I haven't had any issues since.
  12. Boyd Wylie
    Boyd Wylie
    Yes,go buy a vented cap
  13. TheMerc
    TheMerc
    VENTED GAS CAP!!! I messed with that for the better part of a week before I accidentally left it in my pocket one day filling it up!
