some of the work from my shop
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Nov 15, 2011.
  1. cornfieldcustoms
    cornfieldcustoms
    if i cant get to the back of the panel after i weld it in to put primer on it, i will use weld through primer to help protect the metal
  2. JunkYardGuy
    JunkYardGuy
    You've have some cool projects and your welds are like a works of art.
  3. gas & guns
    gas & guns
    Man, you are truly a bad*** mutha.
  4. jhutch713
    jhutch713
    Bro, go to the doctor...you are sick!!!
  5. koolkemp
    koolkemp
    beautiful workmanship and fabrication!
  6. hellenthal
    hellenthal
    from Cincinnati
    I thought I recognized your name somewhere, I have a friend that went to your shop for some heart shaped tow hooks. Small world.
    You have a killer setup out there it looks like. I do CAD by trade and would totally love to have a plasma table at home. You do good work, thanks for sharing it on here.
  7. cornfieldcustoms
    cornfieldcustoms
    been slammed at the shop lately, just not a ton of what i have been doing is picture worthy. lots of welding and grinding. here are a few of the more interesting things i have been doing
    this one is a little OT, but it is still cutting and grinding and some old school style work
    truck in for a chop, laying out some cut marks
    top removed
    starting to put the top back on, has the cut the posts at the top and bottom to line things back up
    front of the roof all squared up and tacked on
    going to have to split the roof to make things better in the rear. going to use this factor seam since the interior is metal and built into the truck. this should be fun
    split at the seam, doing some grinding to make the gaps right
    then cut the back part of the door jam out and slid it back
    then time to make the pieces bridge the gaps
    throw in some pie cuts to line the bottoms up
    starting to get some where
    had to add a piece to the door jam from where it was stretched, used a factory seam to make it look stock
    worked on fitting the door post back on the p***enger side as well
  8. cornfieldcustoms
    cornfieldcustoms
    also started on this, which is my own car, crosley comp coupe, on a ch***is research K88 styled ch***is i built
    bent up a ch***is research style axle for it as well
  9. cornfieldcustoms
    cornfieldcustoms
    also have a 35 ford truck in the shop. have to mount the fibergl*** front end, make a 4 pc hood, running boards and running board braces
    here are the inner fenders
  10. MP&C
    MP&C
    Looks like you guys are staying plenty busy Mike. Nice work!
  11. raprap
    raprap
    from Ohio
    Mike, as usual, you're eye brow deep in great work. Cool Stuff no the less. Need to stop by soon. I'll call.
    Bob
  12. 1lucky1
    1lucky1
    from Morgan NJ
  13. NAS Backyard
    NAS Backyard
    from Lodi CA
    Nice work,! Nice welds ! and Nice shop ! Thanks for sharing !
  14. cornfieldcustoms
    cornfieldcustoms
    busy is an understatement, but being busy is a good problem to have
    thanks for the kind words
  15. murpa
    murpa
    from .
    thats awsome work !
  16. cornfieldcustoms
    cornfieldcustoms
    Another project I am working on, .063 3003 alum. Chute body
  17. ksmith
    ksmith
    Awesome work. I hope I have welds like you in the future! I see you have a tubular X member here. What size of tube did you use and thickness. Im trying to figure out what I want to use in my 31 coupe.
  18. lawman
    lawman
    You are sooo smooth!!!!!!!
  19. cornfieldcustoms
    cornfieldcustoms
    the front x member is 2 in od, .250 wall, the center k member is 1.75 od .125 wall
  20. cornfieldcustoms
    cornfieldcustoms
    a little update on the OT truck chop. made lots of head way while the site was down
    got the driver side door top welded back on
    then pulled the roof skin off to metal work the roof seam, and to make things easier to stretch the inner roof sheet metal
    welded up the roof skin, ground down and some hammer/ dollie time. i didnt get a pic of it but i ran it through the english wheel to smooth it out more
    then moved onto the fun part. the inner skin. i split it at the factory seam and made the new filler spot weld to the flange like it did from the factory. two reasons for that, 1 a lot less welding/ warping, 2 it looks like it was never chopped. filler panels made and clamped up. ****m used to help lay out the trim lines for the fillers
    all welded up and ground smooth inside and out, then some attention with hammer and dollie
    its not perfect but nothing some high built primmer or a skim coat of filler cant fix.
  21. cornfieldcustoms
    cornfieldcustoms
    made some more progress on the roof
    had to make a filler panel to replace where i slid the rear of the door frame back
    all fixed up
    then continued to weld and smooth out all the seams
  22. Very nice!! Impressive.
  23. CaliDreamin'
    CaliDreamin'
    Awesome work. There is tons of motivation here for a 28-29 RPU build I am starting soon. Keep up the good work.
  24. Roadsir
    Roadsir
    You're doing some great work. Neat job on the pickup. I'd like to see a side profile of the roof. It looks like the back of roof will have a much nicer curve to it than the original
  25. jhutch713
    jhutch713
    How much time are you looking at total after you've finished that chop up?? Great work...
  26. cornfieldcustoms
    cornfieldcustoms
    just time in the chop i have about 60 hours in. that is from bracing/ lay out to where i am now
    here are some more profile shots
    got a little more done on my aluminum chute body i am making
    and have been working on finishing the hand made 4 piece hood for a 35 ford truck. hand made from scratch, hand rolled all the hinges with a hammer and dolly. still needs some fine tuning but it is all roughed in
  27. cornfieldcustoms
    cornfieldcustoms
    another shot of the chute body
  28. cornfieldcustoms
    cornfieldcustoms
    been busy working on some OT projects to get them ****oned up. here are some of what i have been up to
    finished up all the metal work on the willys M151A1
    also been working on shaping the custom stretched running boards on the 35 ford truck. these have been challenging with the curve in the boards that match the fenders.
    all the lines laid out for linear stretching
    ran through the power hammer a few times to stretch the edge and roll it over
    starting to smooth everything out with the english wheel
    starting to look like something
    more to come on the running boards as they progress.
    also made an aluminum hood for jo kerr, here i am doing the louvers
    and been working on more custom cut parts on the cnc plasma. SBC header flanges with or with out the block temp sensor cut outs, round or square ports
  29. cornfieldcustoms
    cornfieldcustoms
    more work on the 35 ford truck extended running boards
    using the same card board template as i did for the driver side, just flipped over to lay out for the panel
    panel cut out, high light line laid out, and marked every inch to use as guide when linear stretching
    linear stretch dies in the power hammer
    now it has to get ugly before it gets good
    one complete p***
    p*** two
    first trip through the english wheel
    started folding edges over on the bead roller with a tipping wheel
    when folding the edge in the radius this happens
    a little time with a hammer, dolly and some shrinking
    worked the edges up to a 90 and straightened them up a little with a hammer
    here it is roughed in, still need to do some work on the english wheel, roll the body line in the bottom, and turn the edge under the body line. but it is getting there.
    here you can see the curve of the running board and why it had to be stretched
    [​IMG].
    hope to have the board itself finished up tomorrow and ready to go on the truck
  30. A Rodder
    A Rodder
    I follow you on IG, nice work!
