Working in the new One Car Garage – HAMB drags thrash
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Nov 14, 2012.
  1. seatex
    seatex
    Sweet! Subbed up!
  2. Kevin Lee
    Kevin Lee
    Super Moderator
    Ah, finally circling back here. I knew the lower part of the cab was rusty when I bought it but man... it was really bad.
    I've chiseled the trash away and done the 3.5" channel/sneaky section through the cowl. So time to make some panels, fill the gaps and get it back together.
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    Matboard templates. Simulating the stock panels while accounting for the 3.5" change.
  4. Kevin Lee
    Kevin Lee
    Super Moderator
    Center punched and drilled – MDF backer will do double duty as the hammerform once I circle back with a larger holesaw.
  5. Kevin Lee
    Kevin Lee
    Super Moderator
    Yard sale score: $2 router.
  6. Kevin Lee
    Kevin Lee
    Super Moderator
    This little power nibbler/shear rules.
    Then finish it out with hand snips and a file.
    3dnsouth likes this.
  7. Kevin Lee
    Kevin Lee
    Super Moderator
    Hammer.
    Form.
  8. Kevin Lee
    Kevin Lee
    Super Moderator
    First side.
  9. Kevin Lee
    Kevin Lee
    Super Moderator
    And folding the edge back over to more closely mimic the stock panel.
  10. TV
    TV
    Kevin, good on ya, nice digs.--TV
  11. Kevin Lee
    Kevin Lee
    Super Moderator
    Got busy and work was kind of fragmented from here so I didn't capture the rest step by step, but it involved more hammers, dollys, a tool I made from a chunk of steel and a ball end mill, and some thick angle iron.
  12. Kevin Lee
    Kevin Lee
    Super Moderator
    So there are some errant hammer marks and the measurements aren't exactly the same as they were, but I'm definitely happy with it all.
    I had considered just buying a different cab in better shape. There are a lot of them out there. But the history with this one is 1 of 1 – couldn't bring myself to replace it.
  13. JasonK
    JasonK
    Wrench in one hand, Beer in the other....
    (My motto)
  14. Kevin Lee
    Kevin Lee
    Super Moderator
    Thanks, TV. Still getting it all sorted but I should be in good shape this year.
  15. NoSurf
    NoSurf
    Very nice. I like it. Good job.
  16. Kevin Lee
    Kevin Lee
    Super Moderator
    So a lot more has happened since my last update. Currently wrapping things up at my day job and taking a week off to try and make the drive to the HAMB drags – it's going to be so close. Some days I feel like I've got it all dialed and there's no way it wont happen... some days I'm laughing at myself for even considering that it might be possible. And sometimes I'm taking those turns hour to hour.
    I'm going to drop photos here from time to time over the next week and I'm capturing some video to circle back and post as well. Wish me luck.
  17. Kevin Lee
    Kevin Lee
    Super Moderator
    Here's the 3.5" channel kit for the rear of the cab. They are the B-pillar gussets extended 3.5" with a 1/2" box spacer to compensate for the angle of the pillar. May be more head scratching in this little piece than the rest of the floor... or maybe the entire truck.
    And here they are welded together.
  18. Kevin Lee
    Kevin Lee
    Super Moderator
    It's really been complete chaos in here lately. Late nights, lots of coffee, hallucinations – the whole nine.
    Tuck likes this.
  19. Kevin Lee
    Kevin Lee
    Super Moderator
    On again, off again, check fit – on again, off again.
  20. Kevin Lee
    Kevin Lee
    Super Moderator
    New floors going in as the Illuminati looks on.
  21. Kevin Lee
    Kevin Lee
    Super Moderator
    Z the frame on a fenderless hot rod? No sweat. But factor in a front crossmember that helps support the engine mounts, a radiator support that you're pretty much hanging the entire front wrap from, and – oh yeah – parallel leaf springs with the shackles conveniently centered right below the area you need to drop 3.5".
  22. Kevin Lee
    Kevin Lee
    Super Moderator
    This definitely isn't going to win any style points, but it's solid and I can dial in some of the aesthetic issues in a couple of years when it all comes back apart.
  23. Kevin Lee
    Kevin Lee
    Super Moderator
    ...and this is where I stand right now.
    Steering box has been shifted forward an inch-ish and rotated to compensate for the channel and Z. Rear boxing plates are tacked in place. Patterns for the fronts are made. And I've also finished the center crossmember since I snapped this. (boxed and tied the sides back together)
    So, it's ON. If I can get the frame welded up in a reasonable amount of time I'll move on to ***embling the engine/transmission, exhaust, plumbing, wiring, and the rest. We'll see – I've waffled between laughing an crying half a dozen times as I've posted these last few updates. Haha.
  24. tommyd
    tommyd
    from South Indy
  25. Lotso work there.
  26. flatout51
    flatout51
    Amazing. Finally someone not building your typical F series truck. Can't wait to see this around KC
  27. Kevin Lee
    Kevin Lee
    Super Moderator
    Back burnered the truck, dug it back out, made a ton of progress, and now back again with some dirty tech.
    Look at this and make one of these:
    Find the limits of your shrinker stretcher and improvise a tucking fork:
    Tuck it.
    Hammer, mark, punch.
    Eyeball.
    And fit.
    There are a few odd whacks with the hammer... could I bump and file them out? Yup, but I'm not a shop owner... I'm just a guy in a garage.
    CTaulbert and Tuck like this.
  28. Chucky
    Chucky
    That looks great.....I can smell the welder already!:D
  29. Kevin Lee
    Kevin Lee
    Super Moderator
    Nearly a year later – I just might make it this time.
    KCsledz, NoSurf, Malcolm and 3 others like this.
  30. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    That last pic man... Looks so good!
    Now picture the coupe behind it on the single axle... OH MAN!!!
