Technical Mercury Marauder Engine
Discussion in 'The Hokey Ass Message Board' started by Lancer, May 1, 2014.
  1. Lancer
    Lancer
    Is this the same as an FE motor? I have a bell housing for one but don't know if its the same or not.
  2. thunderplex
    thunderplex
    Where is the pic?
  3. bigs merc
    bigs merc
    It should be. What year did it come out of?
  4. sunbeam
    sunbeam
    In 58-60 it would be a MEL 61 up FE a MEL the valve cover will not cover the edge of the intake.
  5. Lancer
    Lancer
    I don't have the car or engine. Just a four speed that was behind one of those motors. Just curious about the bell housing. Here are some pics. It was in a 57 Fairlane that was an old circle rack car. Ran back in the early 60s. ImageUploadedByH.A.M.B.1398997573.414045.jpg ImageUploadedByH.A.M.B.1398997581.611197.jpg ImageUploadedByH.A.M.B.1398997590.318409.jpg
  6. sunbeam
    sunbeam
    1958-60 MELs use the FE bellhousing pattern. so if the housing came from Merc it will work.
  7. flatjack
    flatjack
  8. Lancer
    Lancer
    What's an MEL?
  9. Oldmics
    Oldmics
    Mercury - Edsel - Lincoln
    Oldmics
  10. Lancer
    Lancer
    Would a casting # help identify? I'll have to s****e of all the grime and look for one.
  11. sunbeam
    sunbeam
    Fords 383 430 462 used mainly in Mercs and Lincolns from 1958-68 Larger and heavyer than FEs.
  12. Lancer
    Lancer
    I'll see if I can find any casting #s or any identifying marks. I'd like to list it for sale but need to know what it is first.
  13. Oldmics
    Oldmics
    Maybe this for a HiPo 260/289 ????
    http://www.cometeastcarclub.org/Comet_Corbra_kit7.html
    Bolt pattern looks to be the same. Reinforcement ribs on your unit could have been a later added production change.
    Dig out the casting number and I will see if I have the correct books to tell what it is. What material is yours made out of?
    Oldmics
  14. Lancer
    Lancer
    Its aluminum Oldmics. Yes, I'll look for a number on it.
    I'm putting it behind a Y-Block.
    The trans that is that came with it. Top loader.
  15. barstowpo
    barstowpo
    As someone said earlier, not a FE. It doesn't have 3 starter bolts.
  16. FrozenMerc
    FrozenMerc
    Definitely looks like a early 5 bolt 289 housing. If it is a FoMoCo casting, the casting number won't tell you much other then the year. First letter and number will give the tooling date. B9 = 1959, C5 = 1965, D4 = 1974, E3 = 1983, etc. That will help narrow it down to what engine family it came from.
    Also, try measuring the spacing on the top bolts. This diagram will help.
  17. Oldmics
    Oldmics
    If you have the MPC Cross Reference Books - then you can get the actual part number from the casting number on the part.
    Maybe its not a well know way to get Ford numbers from what is actually cast on the specific part?
    Oldmics
  18. Lancer
    Lancer
    Outside to outside of the top holes is 6". See the pic for more info. ImageUploadedByH.A.M.B.1399087831.884352.jpg ImageUploadedByH.A.M.B.1399087840.144817.jpg ImageUploadedByH.A.M.B.1399087849.125893.jpg
  19. Lancer
    Lancer
    What do you think guys? Will these numbers help identify?
  20. That's what it is.... Will fit the '62-64 221/260/289 blocks, nothing else.
  21. Mr48chev
    Yuppers and if you google C3AA-6394-C the Ebay link for those things comes up and you see a number of identical ones on Ebay for a whole lot of different prices http://www.ebay.com/sch/i.html?_trk...AA-6394-C&_nkw=C3AA-6394-C&_sacat=0&_from=R40
    Still a decent piece that guys running early blocks are looking for.
  22. Lancer
    Lancer
    Good to know, I can list it up for way less and move it quickly I hope.
