1948 chevy fleetline
Discussion in 'The Hokey Ass Message Board' started by FIRME56, Feb 24, 2012.
  1. x 2
  2. machine1967
    machine1967
    from oshawa
    what size tires are you using to lay it on the ground ?
    will 26 inch tall work
  3. FIRME56
    FIRME56
    Im running 15" wheels on Denmin 5.60 bias ply tires.. its the Jiminez Bros two link that allows it to lay (without cutting the floor).
  4. machine1967
    machine1967
    from oshawa
    what size tires needed to fit under that lowered car
  5. machine1967
    machine1967
    from oshawa
    great info the 5.60 bias are 25.8 inches tall.. I am doing a similar build with a 1948 canadain pontiac hopeing to sit the frame on the ground with 26 inch tall bfg bias tires.
    there is not alot of room for tire height
  6. machine1967
    machine1967
    from oshawa
    I tried to send you some pictures but it keeps failing ,I installed mustang 11 in the front and triangulated 4link in rear solid drive shaft 400 pontiac engine
  7. FIRME56
    FIRME56
    I dig the Pontiac torpedo. . Now that's a ride that needs to kiss pavement. Looks *****in sitting on rails. Get those pics figured out I'm curious
  8. JLepe
    JLepe
    I know these posts are old but hopefully you still get this. How do you like the 2 link set up any issues? Would you recommend it? I have a 47 and I am trying to way my options, thanks
