Technical **Spring has sprung, now get out and drive um..May 2014 banger Meet **
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, May 1, 2014.
  1. Crazydaddyo
    Crazydaddyo
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
  2. Crazydaddyo
    Crazydaddyo
    Copied this from a thread on the main board:
  3. 16 days to ElMirage.
  4. Crazydaddyo
    Crazydaddyo
    Are you ready?
  5. car has been in trailer for a month and nothing is leaking under the trailer...............yet.
    The Flathead is being installed and new manifold is at the welder.
    The Dyno sessions went well, no major mess and we have a good idea what to do for gearing.
    J
  6. Shaun1162
    Shaun1162
    Just a small side project of mine...
  7. Crazydaddyo
    Crazydaddyo
    Ch***is dyno or engine dyno?
  8. Crazydaddyo
    Crazydaddyo
    Interesting, I'm interested in how this works and sounds.
  9. engine
  10. Shaun1162
    Shaun1162
    I'm sure it won't be all that efficient, but I've had a fascination with both homemade Model A intakes intakes, and dual updraft- so I figured I might as well give it a shot. Plus I don't think any of the aftermarket dual updraft intakes would clear my manifolds...
  11. Bluto
    Bluto
    Just waking up in the East :)
  12. RussTee
    RussTee
    Anyone checked out the Gempsa engine in the cl***ifieds?
  13. The Gemsa looks pretty good.
    The history behind it makes it worth the price of admission.
    Someone is going to have a piece of history.
    This morning, I located some patterns from a Indy driver back in the day, DOHC.
    Research begins.
    J
  14. shock
    shock
    Sorta the same !
  15. RussTee
    RussTee
    Finally my drilled **** crank rods and bearings are on the way you cannot belive how hard it has been to arrange this from a remote location they should get their web site sorted.
  16. colinsmithson
    colinsmithson
    Rusty I feel your pain I have 2 of these sets (crank, rods, bearings) from ****
    same deal problems with shipping to this part of the world
    They are very nice and strong you will be happy:)
    I got mine a couple of years and had some minor issues with them that I,am told have been addressed
    interested to hear how you go with yours
    Colin
  17. seadog
    seadog
    Dustyp489 likes this.
  18. Phred
    Phred
    from IL
    Curious...
    Hansel, my warmed over Banger, emits a crackling and popping sound out the tailpipe when the engine is on overrun (fully letting off the throttle when the car is moving fast). Sounds cool, but I am curious...
    1) what causes this? My theory is that the throttle plates are closed, the carb (Stromberg 97) has now shifted into the idle circuit, fuel mixture is now too lean to support combustion in the combustion chamber, but lights off when it reaches the hot exhaust manifold/tailpipe.
    Is my theory correct, if not, what is happening?
    2) Long term, can this cause any damage, and/or does it have a negative effect on performance?
    other than the cool sound, He runs great and the wide band Air/Fuel gauge shows nothing weird (generally 13.X - 14.x AF).
    Thanks in advance for any input.
  19. BCCHOPIT
    BCCHOPIT
    Here is some ****...
    ImageUploadedByH.A.M.B.1399208247.396164.jpg ImageUploadedByH.A.M.B.1399208277.341026.jpg
    WACCUSTOMS.COM
  20. BCCHOPIT
    BCCHOPIT
    I don't know what this engine was
    Some one said GM? The front cover looked like a newer engine.
    ImageUploadedByH.A.M.B.1399208495.712410.jpg ImageUploadedByH.A.M.B.1399208510.245642.jpg ImageUploadedByH.A.M.B.1399208521.051640.jpg
    WACCUSTOMS.COM
  21. ebtm3
    ebtm3
    Common if there is a small air leak in the exhaust system up near the engine. Additional air mixes with slightly rich mixture, all of which didn't burn, and is ignited by heat in manifold, or pipe. No harm that I know of.
    Herb
  22. CTKing
    CTKing
    from Reno,NV
    Took off for the Turlock swap Saturday night hoping to find an exhaust manifold and a tillotson carb for my banger project. I came home with a lot more than planned.
    It was kind of an all or nothing deal.
    Posted using my fat fingers, excuse the typo's.
  23. Checking in.
    At least you did get, what you set out for, CTKing! And spare are always good (at a good price!).
  24. Crazydaddyo
    Crazydaddyo
    If that block came with that multi disk flywheel from the factory, there is a good chance it is a 5 cam bearing block. What is the serial number?
  25. CTKing
    CTKing
    from Reno,NV
    The serial number is A587997. Where can I get some info about the flywheel setup, it's very different from the banger I have been putting together. I thought it was parts of a direct drive system for an ag. application.
  26. Crazydaddyo
    Crazydaddyo
    I think the first 200,000 - 300,00 cars produced in 1928 had the multi clutch set up.
    That serial number is too high for the 5 cam bearing blocks.
    If you search ford bard, I'm sure there are many posts with info on them.
  27. Tedders
    Tedders
    question, when i removed the rad oil/coolant leaked outof the lower water pipe it seemed i have oil mixed into my coolant..more then a little concerned right now
  28. V4F
    V4F
    from middle ca.
    Just waking up in the East ..... good morning jimski .......... steve
  29. V4F
    V4F
    from middle ca.
    my lil motor got a lot of curious looks sat at a show !! LOL funny to watch people look at what they dont know !
  30. Tedders
    Tedders
    Anyone? Little help. Oil out of lower pipe to rad? Little worried
