Hot Rods ID'ing '32, '33, & '34 pickup cabs
Discussion in 'The Hokey Ass Message Board' started by JimSig, May 4, 2014.
  1. When all you have is the cab, how do you tell '32, '33, and '34 pickups apart?
    Thanks,
    JimSig
  2. bowie
    bowie
    Only a'32 cab has a firewall that is flat like a'32 car. The '33&'34 fire wall extends out about2-3 inches from the rear hood line. Also a'34 cab has an extra belt line ridge moulding on the back of the cab. Hope that helps you.
  3. 56don
    56don
    Notice the extra wide belt line under the window on this truck cab. Its the distinguishing mark of a 1934
  4. jkeesey
    jkeesey
    32 cab has a gas tank under the seat.
  5. VoodooTwin
    VoodooTwin
    from Noo Yawk
    As Bowie said; '32 has a firewall that is basically flush with the cowl. '33 has a firewall that protrudes out from the cowl, and no fat beltline under the rear window. '34 has the fat beltline under the window.
    I'm sure there are other differences, but those are the easy distinguishing features.
  6. motorhead748
    motorhead748
    and none of them will have a driver door
  7. bartmcneill
    bartmcneill
    from Ada, OK
    They are all correct. I had a driver door and it went like crazy on eBay.
  8. HOTRODPRIMER
    HOTRODPRIMER
    The 32 Truck has a bolt in firewall,all 32's share the same feature.
    the 33-34 have a welded in firewall and incidentally because of the way it's made allows for a couple of more inches of leg room.
    As mentioned previously the 32-33 cab is basically the same and share the same body line on the back of the cab.
    The 34 has the extra wide belt line along with the lines in the previous cabs.
    It is thought that the extra belt line was to reinforce the cab. HRP
  9. Master of None
    Master of None
    Or they will look like they backed over them a couple of times and then put them back on.:mad:
  10. 51 mercules
    51 mercules
    JIm
    Did you get a cab?Come by and look at my 33.I can show you differences.
  11. falconsprint63
    falconsprint63
    from Mayberry
    I don't mean to sound like a ****, but do a search. there's a HUGE thread on ID'ing these trucks. the basics are covered here, but there's a fair amount of little stuff here and there too.
  12. falconsprint63
    falconsprint63
    from Mayberry
