Projects Plan II - 62 Chevy II Drag Car
Discussion in 'The Hokey Ass Message Board' started by squirrel, Dec 27, 2013.
  1. qzjrd5
    qzjrd5
    from Troy, MI
    Doing a fine job, that thing is killer.
    els likes this.
  2. patman
    patman
    Where did you get the rubber (?) firewall pad?
    els likes this.
  3. squirrel
    The firewall pad is a reproduction, cotton insulation, black cardboard, and rubber strip along the bottom. From Cl***ic Industries.
    This is a kind of strange build, because I'm restoring the car back to original, on the stock parts of it that I'm keeping. The idea is to make it look like it was built into a race car when it was almost new.
    1Nimrod and els like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That's poetry to my ear's (eye's).
    els likes this.
  5. Please tell me you aint runnin that killer master cylinder!!!
    els likes this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    A 2 circuit system is only as good as the backup of it's primary. Together they're one, less than that is just less. Make sence?
    els likes this.
  7. squirrel
    I've been driving with single master cylinders for decades, they haven't killed me yet. FWIW, the hand brake works on the Chevy II.
  8. squirrel
    Trimmed the front fenders to clear the tires. Quite a bit of the stuff on the engine is connected...but no exhaust, wiring, or fuel yet. A few pics for your entertainment.
  9. v8juice
    v8juice
    looking great
    els likes this.
  10. Boones
    Boones
    from Kent, Wa
    will the front tires hit the fenders when it comes down from its wheelies
    els likes this.
  11. DBruce
    DBruce
    Now that's "Entertainment"!
  12. toucan
    toucan
    from sc
    this thing is gonna rock!
    els likes this.
  13. Beautiful! Consider us "Entertained"! And almost no intermissions at this show!
    els likes this.
  14. jfreakofkorn
    jfreakofkorn
    sitting good ...
    els likes this.
  15. patman
    patman
    Hope you don't mind...I couldn't help posting a couple of those into your thread over on SNS... :eek:
    els likes this.
  16. Malcolm
    Malcolm
    from Nebraska
    So damn cool!
    els likes this.
  17. CGkidd
    CGkidd
    I said it before I will say it again. Looks *****in.
    els likes this.
  18. squirrel
    Thanks again!
    I took some stuff apart to do more work. I finally got the front shocks mounted, and added the snubbers between the frame and spring. Cleaned and painted some of the front parts, and swapped the smaller blower pulley onto the bottom. Now it's 3% over, which should get me around 6 or 7 psi boost, I think. This engine is 435 cubes, the one in the 55 that the blower was on previously is 454, not much difference. I got about 5 psi up here in 4500 ft Sierra Vista with the 55 at 3% over.
    I also spent quite a bit of time today figuring out what parts to buy, mainly for the brakes and fuel plumbing. I also put the fuel pickup into the tank. The tank is a new repop stock unit, and I decided to just put a 1/2" pickup tube in it, about 1/3 way back. The bottom of the tank slants forward...so I guess I need to keep half a tank or more of fuel in it when I'm racing, so it won't starve. I am going to run 1/2" aluminum hard line from the pump to the firewall, and there it will have the regulator and two braided lines running to the carbs. I am using nickel plated AN fittings, they are not quite period correct, but they're not too obnoxious like the red/blue ones. If I didn't have to meet NHRA rules, I'd run a lot of normal rubber fuel line, but they only let you use 6 inches total on the whole car.
    spy shot of the pickup tube and sender inside the tank. I checked the sender with an ohm meter after I installed it, it gets 0 ohms empty, 30 ohms full.
  19. jimmy1931
    jimmy1931
    Jim, every aspect of this car is primo. Of course, all you do is top notch. Thanks for sharing all of this with us.
  20. squirrel
    I'll see how this thing works....here goes nothing.
    I've been working on the fuel system, wiring, brake plumbing, and the headers. Fuel is done, brakes are half done, wiring is started. One header is almost done, I just need to paint it. Time now to get the doors painted on the inside, and hung. Pretty soon it will look like an almost finished race car. progress34.jpg progress35.jpg progress37.jpg fuel02.jpg wiring01.jpg headers08.jpg wiring02.jpg
    Desoto291Hemi, 1Nimrod and els like this.
  21. speedyb
    speedyb
    from socal
    Looking good
    els likes this.
  22. squirrel
    Thanks!
    Header, for the driver side. Haven't even started on the other one yet, but I have the experience of having built one header in my life now, so it should be a little easier.
  23. tnich123
    tnich123
    As others have said bad *** and the progress is moving along very nicely.
    els likes this.
  24. Baron
    Baron
    Nice work. Should be a lot of fun !
    els likes this.
  25. squirrel
    Thanks!
    A few shots of the header installed in the car. And I painted some more "inside" stuff red...so I get to install it.
    1Nimrod, els and enloe like this.
  26. wrenchbender
    wrenchbender
    Squirrel I gotta say I don't know how I've missed this but this thing is *****in keep up the good work hope to see this at the hamb drags this year to bad I sold my afx we could have done some match racing guess I need to build another one lol
    Chrome don't get ya home
  27. Hyway Hauler
    Hyway Hauler
    I wish I had your talents...and your motivation! I can't seem to get anything done on my '31 Chevy...of course I work 6 days a week, 12 hour shifts 4000 feet underground, and drive an hour each way...I have no excuses...lol
  28. Looking good! I dig that SHIFTER! What the hell?? o_O
    els likes this.
  29. squirrel
    Try finding an aftermarket automatic transmission shifter from 1966...that's not an Ansen, one with a real gate. They don't exist, except for the Hydro Stick. Mine is a copy of a picture of a B&M Turbo Stick. Like the Hydro Stick, but for a Turbo Hydramatic 400. I have a picture of one...but I don't know if they really sold them.
    1Nimrod, els and Rat Sass like this.
  30. Nice! Everything went on a diet!
    els likes this.
