Technical SBC Distributor whine
Discussion in 'The Hokey Ass Message Board' started by jimstro16, May 4, 2014.
  1. jimstro16
    jimstro16
    I finally finished my '50 Chevy project and have taken it about 300+ miles now. All is going ok with the car other than my ears will not stop ringing after I get out of it. There is a high pitched whine coming from the distributor.
    I have an HEI in it and its a 355 SBC. It doesn't seem to effect its ability to run like it should but it is getting annoying. First I pulled the cap and see no signs of anything rubbing. Then I swapped to another distributor.. the problem still continued. So I shimmed it up with the largest Teflon shim in the Moroso kit. Still whines constantly. The noise does go away when I get on the gas. So it is really a 1000 - 2500 RPM issue
    Any help or suggestions would be appreciated.
  2. I'm not really sure of which goes where or with what but there is a condition with sbc cam distributor drive gears and distributor gears. It's a late vs early discrepancy with those gears. Might be worth looking into . That or cam walk
  3. WDobos
    WDobos
    Just a guess,do you have a cam ****on on the end of the cam,it might be walking in the block
  4. jimstro16
    jimstro16
    The cam walk idea is possible. I didn't build this one so I am unsure what is under the timing cover. Ill have to pull the cover to see what I have
  5. black 62
    black 62
    from arkansas
    your cam is not walking unless it's a roller---you could lap the gears but it has to come apart to do it...
  6. indyjps
    indyjps
    Drain the oil and check for any metallic flake, the high pitch whine sounds like metal on metal, could be cam walk, could be incompatible dist gear to cam, I'm guessing something inside the engine is eating itself throwing shavings.
  7. jimstro16
    jimstro16
    Drained oil and no signs of anything other than oil. Noise goes away when under a load. It seems to be at its worst under idle.
    I really don't want to pull this thing apart after finally finishing it after a year and a half of working on it. Might just have to though
  8. tb33anda3rd
    tb33anda3rd
    could it be the flywheel cover rubbing?
  9. mechanic58
    mechanic58
    Did you put a high volume oil pump in this engine by any chance?
  10. tjet
    tjet
    Does the noise change pitch as the rpm increases? If its constant without a pitch change, make sure you don't have a vacuum leak (may be the source)
  11. jimstro16
    jimstro16
    The flywheel cover is still on the shelf still so I don't think it'll be rubbing.
    I am not sure which oil pump it was built with. The guy I bought it from didn't know much about the build details.
    I did have a tough time getting the timing and air/ fuel mix correct. When I first fired it up, the exhaust was running EXTREMELY hot. I have it running a little rich right now to keep the exhaust temp down while at idle. It cools down when driving.
  12. jimstro16
    jimstro16
    It does have a pitch change when rpms go up and is silent when over about 3000 rpm's
  13. mechanic58
    mechanic58
    If it has a high volume oil pump in it and the crank bearings were not clearanced as required, then you may have too much oil pressure - causing the oil pump drive to whine. I have experienced this many times over the years, mostly with sbc's...probably only because they are so popular and hv oil pumps for them are cheap. Lots of people think they can just slap one on and go - not the case. If this is what's going with your engine, it will tear up your cam/dist gear and maybe even ruin the engine. Check your oil pressure with a mechanical gauge first. If its much more than 55lbs at speed, hot, then you probably have a problem.
  14. badshifter
    badshifter
    It's not the distributor as you swapped them and didn't solve the problem. High exhaust temp is usually retarded timing, and if you have an automatic it could be the pump. Disconnect all the belts and start it to rule out alternator, water pump, fan, p/s pump etc. As to the oil pump, what is the oil re***ure? Drain your oil and put 5/20 in it and see if that helps. Thin oil doesn't build pressure like heavier oil, see if that makes the noise go away.
  15. jimstro16
    jimstro16
    Not sure if it helps but the oil pressure gauge in the car stays steady at about 50 lbs at speed.
  16. mechanic58
    mechanic58
    Is it an electric or a mechanical gauge? Some electric gauges aren't very accurate at all...many won't even read above 50lbs. Anytime I am troubleshooting an oil pressure issue I always connect a mechanical gauge.
  17. jimstro16
    jimstro16
    Quick rundown of parts.
    • ****** headers
    • HEI distributor
    • 2101 style Edelbrock intake
    • 1405 Edelbrock carb.
    • 993 heads, stock style rockers
    • Supposedly it is a .030 over block
    • NV3500 5-speed transmission
    New alternator, water pump, belt all in the last week. Tried 2 different HEI distributors, 2 different alternators, swapped replaced all accessories and still whines
  18. jimstro16
    jimstro16
    Mechanical oil pressure gauge
  19. mechanic58
    mechanic58
    Try the thin oil suggestion - it's easy and doesn't cost much. You could even use diesel fuel if you wanted to, just for a short run test (unloaded), won't hurt anything.
  20. tjet
    tjet
    Did you try a new distributor cap? I've seen a cracked cap leak secondary voltage to the closest ground. It makes a whine sound.
  21. jimstro16
    jimstro16
    Running 10-30 now. Temp stays steady at about 180. Idles like it should.
    I can give it a go, its easy enough to swap oil and see if it makes a difference but it sounds more like a metal rubbing squeal.
  22. jimstro16
    jimstro16
    Not a new one but a different one off my stock car. No squeal on stock car.. like a pig on this engine
  23. tjet
    tjet
    Are u sure the dist is getting enough oil? I think a sbc has a plug that needs to be in place (or was that on my early hemi?)
  24. jimstro16
    jimstro16
    Never really heard of a plug to be in place on the chevs. Plenty of oil on the shaft when I took it out though.
  25. jimstro16
    jimstro16
    Thanks for all the help, I'll try a few things tomorrow and see how it goes.
  26. tjet
    tjet
  27. jimstro16
    jimstro16
    I've got strong oil pressure so I'm guessing the plug is in there in this case.
    But at least I learn something new today.. never knew that there was a plug in there.
