1953 Lincoln Capri disc brakes?
Discussion in 'The Hokey Ass Message Board' started by cornernfool, Sep 17, 2006.
  1. cornernfool
    cornernfool
    Anybody out there done this conversion and what did you use. I don't really want to lower it with new spindles, just make it stop more better. Thanks, in advance for your help. Mike.
  2. cornernfool
    cornernfool
    Sorry, that should read disc brakes. Don't need no **** brakes, my wife puts those brakes on enough.:eek:
  3. Salty
    Salty
    from Florida
    he he he sorry I dont have an answer for ya, I just thought it was pretty friggen funny.......seeing as I just got the ol' **** brakes as well....(she's not feeling good;) )
  4. KustomLincolnLady
    KustomLincolnLady
    Try master power brake, they probably have a disc kit you can purchase..
    really should consider lowering it though. You may get a nose bleed sitting up that high :p
  5. cornernfool
    cornernfool
    Still looking for disc brake ideas, might even consider going with the droped spindles if any one knows of these. Thanks.
  6. yorgatron
    yorgatron
    '53 Lincoln has a ball-joint style front end,right?
    i would 1st remove the spindle from your car and make sure the taper is the same as other FoMoCo products.
    then i would measure the height of the Lincoln spindle and head for the junkyard and start looking at late model Ford spindles.
  7. twofosho
    twofosho
    Try Scarebird Mechanical out of Seattle. They've got adapter bits made up for all kinds of off the wall swaps, might even be able to make somthing up for you.
  8. 53sled
    53sled
    from KCMO
  9. Bigcheese327
    Bigcheese327
    Holy ancient thread, batman, but it appears cornernfool is still around and still has the car. Did you ever find a solution?
    I thought this was a clever idea. It would be great if something like an F150 spindle swapped in.
  10. cornernfool
    cornernfool
    I ended up taking the factory spindles out to ABS in Orange, Ca. They made a set of plates along with F/E150 rotors and GM Calipers for me. Narrowed the wheel track from 61.5 to 60", which is the same width as the 9" I put in it.
  11. derthor
    derthor
    from Germany
    Do you have any pictures of the disk setup??? I want to take disks onto my 54 Capri and have to build everything by myself ´cause here in Germany it is not so easy to find Lincoln parts ;):D
